iClone 5 Quick Fix Tutorials
Posted By KaiD 15 Years Ago
KaiD
KaiD
Posted 15 Years Ago
Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)Distinguished Member (6.5K reputation)
Posts: 112, Visits: 1.2K
iClone5 Quick Fix Tutorial - Scene Creation
If you're just starting out with iClone, you'll probably want to know a little bit about the basics of how you can create your starting scene. This tutorial will not only show you how to create a beautiful scene using iClone 5's new height map terrains, but also how to enhance it and make it more visually appealing by adding special lighting, shadows, and other atmospheric effects.
iClone5 Quick Fix Tutorial - Facial and Body Customization
Character creation is one of the coolest features with iClone.  If you've ever wanted to bring one of your real-life heroes into the virtual world of iClone, this tutorial will give you a brief introduction of how.  Learn the simple basics of how to import in a facial photo into iClone and create your own virtual character.
iClone5 Quick Fix Tutorial - Facial Puppet Motion
Creating facial emotions and getting your character to talk in iClone is easy! This tutorial will give you a brief look at the facial puppet tool that allows you to record various emotions in real-time, and even use audio clips, your own voice, or text-to-speech to get your character to lip-sync the words.
iClone5 Quick Fix Tutorial - Layering Animation Part 1
There are a wide variety of options for animating your characters in iClone. This tutorial will run you through one of the most simple methods, known as body puppet motion. By using this feature, you can easily create and customize your character's animation in seconds, not hours. In this two-part tutorial, you will learn how to gradually layer and mask different unique motions over each other to create your final fully-customized animation.
iClone5 Quick Fix Tutorial - Layering Animation Part 2
iClone5 Quick Fix Tutorial - Instant Animation
iClone provides the Persona which is the characteristics given to the actor so that the actor can animate in a unique style. One Persona file may include several sets of movement behaviors for your quick animation.
iClone5 Quick Fix Tutorial - Rigid Body Physics
The physics engine in iClone 5 provides you with a whole new realm of possibilities with your animations. One of the essential things you'll need to know is rigid body physics. In this Quick Fix tutorial, you'll learn the basics of assigning physics to your objects, importing in infinite planes, as well as quickly multiplying your props to create stacks of collapsable objects.
iClone5 Quick Fix Tutorial - Soft Body Physics
This Quick Fix tutorial will give you a brief look at the potential of soft body physics in iClone 5. Learn how to change the properties of on-screen props by assigning them soft body physics. Also, you'll learn some basic tips on the cloth soft-body physics props, and how to refine the collision results with other objects.
iClone5 Quick Fix Tutorial - Post FX
Post FX is a cool new tool with iClone 5 that allow you to apply certain keyable effects to your scene in order to enhance the atmosphere and create a whole new kind of feeling as your scene plays along. This simple tutorial will introduce you to the simple way of applying Post FX to your scene.
iClone5 Quick Fix Tutorial - Toon Shader
If you've ever wanted to give your scene a unique or more energetic and cartoon-like sort of feel to it, iClone 5 has the tool that you need. The Toon Shader allows you to apply cartoon-like shading to your scene objects to give it a simple yet charming and fun sort of look. Whether you are going for a bouncy cartoon scene full of life or a stylish anime scene, this is a tool that you'll want to know more about. Look at our developer tutorials on Toon Shader for a more in-depth learning experience.
