iClone 5 Quick Fix Tutorials
https://forum.reallusion.com/Topic102200.aspx
Print Topic | Close Window
By KaiD - 15 Years Ago
iClone5 Quick Fix Tutorial - Scene Creation
If you're just starting out with iClone, you'll probably want to know a little bit about the basics of how you can create your starting scene. This tutorial will not only show you how to create a beautiful scene using iClone 5's new height map terrains, but also how to enhance it and make it more visually appealing by adding special lighting, shadows, and other atmospheric effects.
iClone5 Quick Fix Tutorial - Facial and Body Customization
Character creation is one of the coolest features with iClone.  If you've ever wanted to bring one of your real-life heroes into the virtual world of iClone, this tutorial will give you a brief introduction of how.  Learn the simple basics of how to import in a facial photo into iClone and create your own virtual character.
iClone5 Quick Fix Tutorial - Facial Puppet Motion
Creating facial emotions and getting your character to talk in iClone is easy! This tutorial will give you a brief look at the facial puppet tool that allows you to record various emotions in real-time, and even use audio clips, your own voice, or text-to-speech to get your character to lip-sync the words.
iClone5 Quick Fix Tutorial - Layering Animation Part 1
There are a wide variety of options for animating your characters in iClone. This tutorial will run you through one of the most simple methods, known as body puppet motion. By using this feature, you can easily create and customize your character's animation in seconds, not hours. In this two-part tutorial, you will learn how to gradually layer and mask different unique motions over each other to create your final fully-customized animation.
iClone5 Quick Fix Tutorial - Layering Animation Part 2
iClone5 Quick Fix Tutorial - Instant Animation
iClone provides the Persona which is the characteristics given to the actor so that the actor can animate in a unique style. One Persona file may include several sets of movement behaviors for your quick animation.
iClone5 Quick Fix Tutorial - Rigid Body Physics
The physics engine in iClone 5 provides you with a whole new realm of possibilities with your animations. One of the essential things you'll need to know is rigid body physics. In this Quick Fix tutorial, you'll learn the basics of assigning physics to your objects, importing in infinite planes, as well as quickly multiplying your props to create stacks of collapsable objects.
iClone5 Quick Fix Tutorial - Soft Body Physics
This Quick Fix tutorial will give you a brief look at the potential of soft body physics in iClone 5. Learn how to change the properties of on-screen props by assigning them soft body physics. Also, you'll learn some basic tips on the cloth soft-body physics props, and how to refine the collision results with other objects.
iClone5 Quick Fix Tutorial - Post FX
Post FX is a cool new tool with iClone 5 that allow you to apply certain keyable effects to your scene in order to enhance the atmosphere and create a whole new kind of feeling as your scene plays along. This simple tutorial will introduce you to the simple way of applying Post FX to your scene.
iClone5 Quick Fix Tutorial - Toon Shader
If you've ever wanted to give your scene a unique or more energetic and cartoon-like sort of feel to it, iClone 5 has the tool that you need. The Toon Shader allows you to apply cartoon-like shading to your scene objects to give it a simple yet charming and fun sort of look. Whether you are going for a bouncy cartoon scene full of life or a stylish anime scene, this is a tool that you'll want to know more about. Look at our developer tutorials on Toon Shader for a more in-depth learning experience.
By mark - 15 Years Ago
THANKS! SUPER TUTs! :D
By sumthinwong - 15 Years Ago
ditto
By intrestNL - 15 Years Ago
Hi Kaid,
Great and clear explanations!
You give the feeling that the sky is the limit in such an easy way. Also this tut. gives me so much energy to go on with my own project with a big smile ;)
Thank you so much!!!!!!!
By col757 - 13 Years Ago
iiClone5 Quick Fix Tutorial - Facial and Body Customization
IS COMPLETE AN UTTER BULL
i have repeatedly tried this and no way does it let you set your own face from the photo, IT HAS A PREMADE MODEL IN THE LEFT HAND SIDE OF THE SCREEN, in this tutorial is shows that you can customize it, but on mine you have to import the photo BEHIND the model head, i have i clone 5 just like this one
By Rampa - 13 Years Ago
here is a recent tutorial:
http://www.medianetic.com.my/marketing/iClone%205_3D_model_tutorial.mp4
Here is the RL tutorial page.... Errr...... 17 pages for reference:
http://www.reallusion.com/reallusiontv/tutorial.aspx?category=ic
By Peter (RL) - 13 Years Ago
col757 (10/20/2013)
Please take a look at the video below. This explains how to create a custom head in iClone. If you continue to have problems, then please check your graphics drivers are up to date. If you are seeing your facial texture behind the head then this is not normal. :)
They are NOT tutorials they are just messing with pre existing functions, wheres the proper tutorials?
By animagic - 13 Years Ago
Well it's software so it would be pre-existing functions... I don't know why you put yourself through all this aggrevation, unless you get a kick out of it...:unsure:
By lesfarrx - 12 Years Ago
Thank you so much! As a few day old newbie, I found this extremely helpful. Question: is it OK to select Macromedia Fireworks for my Preference Window or do I need Photo Shop (which I have on my desktop but have never used)? I also enterd Microsoft's XML Notepad as my XML editor.
Thanks again.
Leslie Farr
By Peter (RL) - 12 Years Ago
lesfarrx (2/16/2014)
Thanks again.
Leslie Farr
Photoshop will be the much better choice for texture editing. :)
