Daz4 Genesis
Posted By Benduncsnum2 14 Years Ago
Posted 14 Years Ago
wendyluvscatz (8/21/2011)
when I browsed to get the link for my image I hadn't seen your image Peter, I am impressed and a tad peeved at Daz that I can't get Genesis into Carrara yet but you can in iClone!:w00t:
Hi Wendy
I know it's a little bit of an outlay but with 3DXchange4 Pro it will take just a few minutes to get your Daz3D content into iClone (including the new Genesis figures). If you have a lot of Daz content then 3DXchange4 Pro will be invaluable. :)
wendyluvscatz
wendyluvscatz
Posted 14 Years Ago
Senior Forum Member
Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)Senior Forum Member (12.2K reputation)
Posts: 2.5K, Visits: 19.4K
I AM weighing up whether to get $200 worth of iClone content, or DA points or getting the pro version of iC4 (I only have standard) in order to get 5
and running out of time!!!
dunno if I can afford the 3Dx upgrade too!
pity software can't at least have a percentage of that $200 applied
bearing in mind I'd need iC4pro as well as the fbx capable 3dxchange
the content is still looking the better deal unless I can use purchased DA points towards future software too, even if it is the Kinect plugin.
not so worried about bringing in my Daz figures actually, more interested in the pro version for BVH import so I can use the same animations on similary textured figures
the heads can be made very alike easily enough and I have used Daz textures fitted to clothing templates.
bluemidget666
bluemidget666
Posted 14 Years Ago
Last Active: 9 Years Ago
Posts: 3.5K, Visits: 13.8K
Hi
I have just tried to export a fbx file with facial animation a few expression changes but I can not find them in 3dexchange.. now as im new to this I may be doing somat wrong any ideas ?
Right
2012 fbx export no animation in 3Dexchange
2011 fbx export no animation in 3Dexchange
2010 fbx export take time to import then crashes ......
2009 fbx export same as 2010...............
2006 same as 2009
not just facial animation .....
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
bluemidget666
bluemidget666
Posted 14 Years Ago
Could anyone else who have the tools for this pipeline give it a go to see if the errors I'm getting are not just limited to me ...
bluemidget666
bluemidget666
Posted 14 Years Ago
Hi
Right after having a play I can say that the Genesis and V4 models transfer over to Iclone ok with animations though no facial ... but some of the 3Dunivers characters do not.......
tylerzambori
tylerzambori
Posted 14 Years Ago
Posts: 228, Visits: 2.5K
hi bluemidget,
I've been working a show, but should have some time
to play with it too.
cheers!
Tyler
__________________________________
"I am not a senior anything."
bluemidget666
bluemidget666
Posted 14 Years Ago
Hi Tyler
I just had a problem getting Daz to take the serial for the Games Developer Kit turnes out that when I pasted the serial it put spaces at the front of the serial ... might help with your problem..:)
tyler zambori
tyler zambori
Posted 14 Years Ago
Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)Veteran Member (555 reputation)
Last Active: 12 Years Ago
Posts: 39, Visits: 329
Thanks bluemidget,
Today I will get back into trying to get it installed.
I found something this morning that could be very useful:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=88362
This will let you apply all of your old v4 and m4 morphs onto
genesis. You have to have several genesis accessories for this
to work. Since genesis imports in Iclone much better than
gen 4, this is great news.
I still want to be able to just stick a clonebone skeleton
onto it when it comes into Iclone, though. If that could
happen, I would not care about not being able to export
the character out of Iclone, I would just happily use it in
Iclone. ( hoping for the future).
Tyler
bluemidget666
bluemidget666
Posted 14 Years Ago
Hi
I dont think clonebone would be the solution as it needs you to hack ya mesh into bits first.. To my mind a better solution would be to  rig the mesh in 3Dexchange then export to Iclone. I also think that if RL address this issue it would be in this manner but there is a call for a cheeper pipeline than the MAX and MAYA one....
tyler zambori
tyler zambori
Posted 14 Years Ago
bluemidget666 (8/26/2011)
Hi
Righton, rigging in 3dxchange sounds good.
