MakinMovies
MakinMovies
Visits: 716
in the recent webinar about PBR in iClone 7 ( https://www.reallusion.com/press/Webinar/170418_iC7_webinar_ic456/default.html), a truck (free from https://sketchfab.com/models/83a370102fe8498bac52821df987da11) is brought into iClone, having first been converted in Blender from a Collada file to obj. however, i don't think that the tutor, cris moras, demonstrated how to get the shaders (which include five multi-mateirals) transferred and they don't match the kinds of shaders shown in the genie lamp example that he does explicitly show in 3DX, so that when i bring the truck asset into iclone, it does not have the right look at all. I must be missing something, probably very obvious, but i am not sure what.
Visits: 21.9K
Couldn't see the webinar (never was invited and it's not posted anywhere) and that truck link you posted doesn't work so it's hard to say, but unless you're using iClone7 I don't think you're going to get the look you might be expecting from PBR. If you ARE using it you might want to post this in the iClone 7 beta forum instead and we could discuss (we're not supposed to do that elsewhere).
MakinMovies
MakinMovies
Visits: 716
this is the link for the recorded webinar: https://www.youtube.com/watch?v=21-S2lxCjUEthe tutor is shown using 3DXchange 6 for the collada to obj conversion, but for this asset i have since learned that one should indeed be using iClone 7 for the material/texture assignments and therefore this should be discussed in the iC7 beta forum, as you suggest.
Visits: 21.9K
Thanks for the link - I've been wanting to see that presentation.
Space 3D
Space 3D
Visits: 1.6K
Reference import model from the other 3D tool . ( Via 3D exchanges ) Best file for import is Fbx format. If your file is DAE --------> use Free Fbx converter from Autodesk . After your file to be Fbx format ---------> then import with 3D exchanges to iClone . Material and texture will be better . ----------------------------------------------------------------- Visit Space 3D Galery - city.reallusion.com/store/space3D
