michael7
michael7
Visits: 1.2K
I'm just at the edge of buying the Neuron. I have a question for anyone who ones it, how good it the finger control? The reason I ask is I noticed in the videos there is only 1 sensor per finger. A finger has three digits, how does it function when you want to do intricate finger movements? I assume it doesn't and you have to edit these?
Mr. Perfect
Mr. Perfect
Visits: 641
michael7 (8/10/2016) I'm just at the edge of buying the Neuron. I have a question for anyone who ones it, how good it the finger control? The reason I ask is I noticed in the videos there is only 1 sensor per finger. A finger has three digits, how does it function when you want to do intricate finger movements? I assume it doesn't and you have to edit these?
I just ordered my Suite, I will tell you when it gets here. In the meantime I guess that the sensor calculates the movement of the other bones as well, since fingers usually bend all the same way, like it's not that you only bend the finger tip when you bend your finger. But I am just guessing.
michael7
michael7
Visits: 1.2K
Mr. Perfect (8/10/2016)
I just ordered my Suite, I will tell you when it gets here. In the meantime I guess that the sensor calculates the movement of the other bones as well, since fingers usually bend all the same way, like it's not that you only bend the finger tip when you bend your finger. But I am just guessing. Thanks, appreciate that! About the fingers though. You do bend different segments of the fingers depending on what you are doing, like playing the piano, guitar, typing on a keyboard etc. Even with different finger gestures.
Mr. Perfect
Mr. Perfect
Visits: 641
Next week the Suite should be here. I will tell you.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.3K
Thumb and index have 2 sensors. the other one.one sensor at the finger end with IK makes coherent movement. Just for info , the Reallusion coupon makes the suit at the same price than academic.
diomkal
diomkal
Visits: 4.2K
< Just for info , the Reallusion coupon makes the suit at the same price than academic>
Himtakerkart, are you sure? I needed the 18 Neuron academic. If then, how do iget this code? And could you please show me where i could read this info? Thatwould eliminate a lot of my concern. Thanks in advance
Mr. Perfect
Mr. Perfect
Visits: 641
You need to buy the plugin, toghether with that you get the coupon code which you can use at the noiton shop while checking out. It will save you 20%.
Mr. Perfect
Mr. Perfect
Visits: 641
I ordered and it worked out good. Just waiting for delivery now.
diomkal
diomkal
Visits: 4.2K
Thank you very much. Now I understand everything. (Dankeschön)
dogged2003
dogged2003
Visits: 4.5K
Here I found an example. And the example is not encouraging:
My YouTube channel.
