Finger sensors
https://forum.reallusion.com/Topic293781.aspx
Print Topic | Close Window
By michael7 - 10 Years Ago
I'm just at the edge of buying the Neuron. I have a question for anyone who ones it, how good it the finger control? The reason I ask is I noticed in the videos there is only 1 sensor per finger. A finger has three digits, how does it function when you want to do intricate finger movements? I assume it doesn't and you have to edit these?
By Mr. Perfect - 10 Years Ago
michael7 (8/10/2016)
I just ordered my Suite, I will tell you when it gets here. In the meantime I guess that the sensor calculates the movement of the other bones as well, since fingers usually bend all the same way, like it's not that you only bend the finger tip when you bend your finger. But I am just guessing.
Mr. Perfect (8/10/2016)
Thanks, appreciate that! :)
About the fingers though. You do bend different segments of the fingers depending on what you are doing, like playing the piano, guitar, typing on a keyboard etc. Even with different finger gestures.
Next week the Suite should be here. I will tell you.
By mtakerkart - 10 Years Ago
Thumb and index have 2 sensors. the other one.one sensor at the finger end with IK makes coherent movement.
Just for info , the Reallusion coupon makes the suit at the same price than academic.
By diomkal - 10 Years Ago
Just for info , the Reallusion coupon makes the suit at the same price than academic>
Himtakerkart, are you sure? I needed the 18 Neuron academic. If then, how do iget this code? And could you please show me where i could read this info? Thatwould eliminate a lot of my concern. Thanks in advance
You need to buy the plugin, toghether with that you get the coupon code which you can use at the noiton shop while checking out. It will save you 20%.
I ordered and it worked out good. Just waiting for delivery now.
Thank you very much. Now I understand everything. (Dankeschön)
By dogged2003 - 10 Years Ago
Here I found an example. And the example is not encouraging:
Insert as video is not working. Direct link:
http://www.youtube.com/watch?v=wiVMWMNxrf4
By TopOneTone - 10 Years Ago
Thanks so much for posting this. As usual, I got a bit over excited with the launch advertising. The hands were the main reason I was considering investing in this and now I can see how poor it is l will give it a miss. Maybe future developments will extend the sensors into a full finger control, but now I see it in action I realise the current glove cannot deliver finger picking, typing, writing or shooting the keys...
The body control is fantastic but hands and facial control are the top priorities for me, as these remain the biggest limitations of Iclone in my book.
Cheers,
Tony
By Melanie (RL) - 10 Years Ago
Hi dogged2003,
This is the sample using beta version, but the finger issue was fixed and improved a lot, you may find the release note here:
https://forum.reallusion.com/293298/iClone-Mocap-Plugin-v11-Release-Note
Melanie
dogged2003 (8/11/2016)
Show improvements in mocap on video please.
PS. What are the plans to improve the mocap plugin for the Kinect? At least to the level of Brekel?
Thank you.
By jsweare - 10 Years Ago
Yes - not a lot of dexterity captured
- am thinking about purchasing the product
- and have in mind capturing the motion associated with ""handwriting""
- guessing there would be limited results**
**notwithstanding doing meticulous
- motion and key framing within iClone....
