Iclone 5 Virtual Studio ver 2
Posted By RMdog 15 Years Ago
RMdog
RMdog
Posted 15 Years Ago
Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)Veteran Member (558 reputation)
Posts: 67, Visits: 172
Hi
Iclone 5 Virtual Studio # 1 - all projects and props seem to render fine.
Iclone 5 Virtual Studio # 2 (just bought) - all three projects (Oval Office, Stage & President Conference) incorrectly render.
Note: Testing the props from the projects of Virtual Studio # 2 - the props render correctly.
Thus there seems to a problem with JUST the three "whole projects" of Virtual Studio # 2.
I am using the same exact output / HD 720p rendering settings.
See attached photo
Please advise :) -
Thanks !
Apparition
Apparition
Posted 15 Years Ago
Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)Distinguished Member (11.5K reputation)
Last Active: 10 Years Ago
Posts: 2.2K, Visits: 4.0K
Have you checked your texture map settings?
Mike Aparicio-Reallusion Certified Innovative Content Developer
RMdog
RMdog
Posted 15 Years Ago
I am confused. Texture map settings for ...? Individual props...???
The props loaded individually work / render fine. I can even bring in several at one time.
It is just when loading the PROJECT (all the props together) is when this occurs.
So I am clueless to your reply.
Can you give me another HINT?
Posted 15 Years Ago
Posts: 23.1K, Visits: 36.6K
rmathew13 (10/11/2011)
Hi
See attached photo
Please advise :) -
Thanks !
Hi..
I have tested the three projects and they render to image and video just fine. I tried the HD settings you used and again I could find no problem at all.
Have you tried rendering a short video to uncompressed AVI and see if the images are still poor quality. Also make sure you have Pixel Shader mode selected in Preferences with all shader options turned on. This is important to get the best quality results from projects like these.
If you still find the problem persists whichever video format you use then please contact Tech Support using the link below. They will be able to advise you further.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Thanks.
RMdog
RMdog
Posted 15 Years Ago
Yes - I tried everything you have posted. But still trouble.
Note: on the AVI - the Stage will render correctly - but the other two (Oval & Press room) both
remain problematic.
I will contact the help support...
RMdog
RMdog
Posted 15 Years Ago
Here is the response:
Thanks for your detail information.
Yes, we can reproduce this issue, we had passed it to our development team to check it.
They need more time to check it, if we have any message, we will inform you again.
Sorry for any inconvenience caused.
Thank you very much.
Best Regards,
Eunice
Technical Support
Reallusion Inc.
