how to open i clone 4 pro file in iclone 5 pro
Posted By suresh.jallipalli1 15 Years Ago
suresh.jallipalli1
suresh.jallipalli1
Posted 15 Years Ago
Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)Senior Member (388 reputation)
Last Active: 12 Years Ago
Posts: 12, Visits: 38
hi,
i have an issue here,
when i am opening an i clone 4 file in i clone 5,i m getting an error message "iClone.exe has encountered a problem and needs to close. We are sorry for the inconvenience." and my i clone is getting closed.can you help me by saying why this thing was happening ?
Posted 15 Years Ago
Posts: 23.1K, Visits: 36.6K
What type of file is it? Is it a Project, Avatar, Prop? Please explain a little more.
yaRincewind
yaRincewind
Posted 15 Years Ago
Last Active: 8 Years Ago
Posts: 1.2K, Visits: 4.8K
Perhaps this helps:
(Found out by Bluemidget666 in https://forum.reallusion.com/FindPost95698.aspx)
Ok I said earlier that large Iclone 4 project files crash Iclone 5 after a lot of playing around I found out its not the project size that is the issue its any Iclone 4 project file that has a prop attached to the terrain that crashes 5 ..... using the attach to terrain function ....
________________________________________________________________________________________________________________________________________
Danke für Flex - Haare und Kleidung, die nicht durch den Avatar gehen !
suresh.jallipalli1
suresh.jallipalli1
Posted 15 Years Ago
It is an iclone 4 pro project file.when i am opening it it just showed the error message and closing.
suresh.jallipalli1
suresh.jallipalli1
Posted 15 Years Ago
On the same machine when I use iclone4 to open a project file x, it works. But when I try to open the project file x using iclone5 on that same machine, the software crashes. So it is not a hardware problem, eh?
bluemidget666
bluemidget666
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 3.5K, Visits: 13.8K
Hi
what you could do is load your project in Iclone 4 save it as a copy then work on the copy .. then start deleting aspects of your project ... particles,props animations,bit by bit then save out and load into Iclone 5 this way you can find out what the problem is and you keep your original project so when you do know what it is you can just delete that from your project ...
I Make My Mates Do The CanCan For The Amusement Of Killer Robots:D
shygirl
shygirl
Posted 15 Years Ago
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Last Active: 7 Years Ago
Posts: 1.3K, Visits: 8.3K
If you navigate to your iClone 4.0 Project file (on my PC running Windows 7.0 this is C:\Users\Public\Documents\Reallusion\Custom\iClone 4 Custom\Project\ )
Copy and paste one or all of your custom projects and just pop it in your iClone 5.0 Custom Projects folder  (C:\Users\Public\Documents\Reallusion\Custom\iClone 5 Custom\Project)
You can then open it from within iClone 5.0.
I've tried the old method of right clicking and open with iClone 5.0 but this doesn't work for me now.
Hope this helps.
Shy :)
"O wad some Power the gift tae gie us, to see oursels as ithers see us!"
suresh.jallipalli1
suresh.jallipalli1
Posted 15 Years Ago
Thanks Blue. I am not sure, but it looks to me that all my iClone4 projects that have a terrain are not opening up in iClone5. Because I am curious to work on iClone5, am happy to do this for a project or two - but I am hoping there would be a better solution.
Also apologies for having created this separate thread, I should have posted in the iClone Issues thread. I have now posted one there - and would delete this one if possible.
