More Than one Instance of The Same Particle Effect in the Same Scene.
Posted By hopemanjohn 14 Years Ago
The Mythical Dragon
The Mythical Dragon
Posted 14 Years Ago
Posts: 1.1K, Visits: 4.7K
hopemanjohn (7/26/2011)
Hi,
I have another problem!!
I have a series of scenes which start with my actor beaming in on a transporter beam then carrying out a series of dialogues and movements before ending the scene by beaming out.
Now I purchased from the store the Si-Fi Adventure 01 which has a Particle (Transporter Beam Effect), exactly what I was looking for. The Mythical Dragon was the Author.
Now, I can get it to load into my set at the start, my character appears on cue, carries out all motions and dialogues but I can’t get the Prop Particle to activate again to end the scene.
I am sure I must be able to be use it more than once in a scene, or is it possible that it can only be used once.
I emailed the author and am still waiting a reply but I believe that it’s me that’s getting it wrong and not the effect.
Hi John,
I got your email and sent you a reply. For anyone else in the forum who may want to know: The beaming effect is several particle effects running at the same time. Each of these particle effects can be turned on and off with the timeline or in the Modify Panel. Just turn them on when you want it to start and turn them off when they have run the length you want them too. The size and shape of the beaming effect can also be changed to suit your scene in the Modify Panel by adjusting the height and width of each effect.
Hope this helps, if you need more info please email me at: The_Mythical_Dragon@yahoo.com
-Doug
Doug
https://forum.reallusion.com/uploads/images/802f671e-1d55-4dbc-a395-f18a.gif_https://forum.reallusion.com/uploads/images/7f5306f9-14c6-4916-834c-f953.gif_https://forum.reallusion.com/uploads/images/a3af5e54-2406-46ea-8f58-db07.gif_https://forum.reallusion.com/uploads/images/da100d59-8890-4a1b-be9f-8625.gif_https://forum.reallusion.com/uploads/images/777c3084-929c-48a3-955e-2fc4.gif_https://forum.reallusion.com/uploads/images/7e79a164-2793-4c00-961a-c1f3.gif_https://forum.reallusion.com/uploads/images/e3a85212-4fba-40cc-8c92-c44c.jpg_https://forum.reallusion.com/uploads/images/aaccd877-cd18-4557-ab61-b0e3.gif
https://forum.reallusion.com/uploads/images/6d3e7e09-6d95-4bac-81f7-84d0.gif__________https://forum.reallusion.com/uploads/images/9d264a7f-6043-4252-8d4a-f877.png__________https://forum.reallusion.com/uploads/images/ef484605-a020-4395-b2f1-778b.png
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
Why not try sending a personal message to the author of this pack. That way the next time they access the forum they will be able to see your message. The Mythical Dragon's profile page is below.
https://forum.reallusion.com/UserInfo16506.aspx
hopemanjohn
hopemanjohn
Posted 14 Years Ago
Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)Veteran Member (521 reputation)
Last Active: 14 Years Ago
Posts: 5, Visits: 20
Hi,
