make character walk
Posted By mrhankey55 14 Years Ago
mrhankey55
mrhankey55
Posted 14 Years Ago
Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)Junior Member (197 reputation)
Last Active: 14 Years Ago
Posts: 7, Visits: 12
hi,
totally new to crazy talk and keen on using animations.  tried goanimate which is ok but limited.  first off i cannot do simple things though like make a character walk across the room.
i can select in the action menu of the character to walk but he just walks on the one spot.  how can i move him across the room?
the videos are good it showing you what you can do but i would like to know how you do it?
does each movement of the character need to be a new scene?
thanks for any help
Posted 14 Years Ago
Posts: 15.8K, Visits: 31.4K
Do you mean Crazy Talk Animator? Crazy Talk is for animating faces only.
Assuming CTA, I believe you need to advance the timeline and then move the character to the spot he/she is supposed to walk to.
mrhankey55
mrhankey55
Posted 14 Years Ago
yeah i mean animator pro.
i am unsure how that will work to be honest.  seems pretty difficult to do that to be honest and does not run smooth at all.
so really it could take a long time to have the character move across the room then in reality.
its a shame then if there is no simple way to do it as i am desperately looking to purchase software and though this would be the best and easiest to use.
thanks anyway
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
mrhankey55 (7/5/2011)
hi,
thanks for any help
Hi..
This is very easy to do. Just follow the video through below and you should get the idea.
mrhankey55
mrhankey55
Posted 14 Years Ago
thanks however i am finiding it difficult to understand how to make it all work.
new to animation and flash so maybe you can help.
i used goanimate breifly as it was really simple to work and go through the scenes but was a bit limitless and they owned the animations in the end.
so looking for something easy to use like that but where i own the animation.  i have trialed toon boom and this and this is a bit more easier but still finding it difficult.
the timeline, how does this work?  is youe whole movie one scene?  or what?  do you need to create a new scene for each movement of the character?
with goanimate i click new scene and dragged characters in, background and made them move or not and it was easy.
if you can help give me a brief of how it works i.e. how the timeline is in lamens terms i reckon i could pick it up and purchase the full version but i need to know just the basics of how a movie works with your software.
your help is greatly appreciated.
p.s. once the movie is created, do i own the movie?
Posted 14 Years Ago
Hi..
To create animations in CTA you will make use of the Timeline frequently. This is where keyframes are placed as you move your character about.
The normal way you would work on your movie is to create it in one or more "Projects". So for example if you had a movie that was set in two locations, say a house and a park, then you would create these two scenes separately. Then you would export them to video and then join them up in a video editor afterwards. Of course if your movie is set in only one location then you can record the whole thing as one single project if you wish.
I'm afraid to get the most out of CTA will require a little learning first. The best thing to do is watch as many of the video tutorials as you can HERE. Also read through the Help Guide (Press F1 in CTA) and these will guide you on your way.
As a simple example to get you started try the following.
1) With a new empty project started, try dragging one of the comic characters into your scene and place him/her on the right hand side.
2) Now drag the Play Bar (under preview window) to say Frame 200. Then move your character from the right hand side over to the left hand side by dragging him with the mouse.
3) Finally use the play controls to wind back to the beginning and and press Play. You should see your character move across the screen from left to right.
Now although you never even opened the Timeline, what you have done is set a keyframe for your character to move from the left side of the screen to the right side at frame 200.
Obviously you now need to give your character a walk animation to make it look realistic. You do this by opening up Puppeteering from the left toolbar and and then record a simple walk motion from frame 1 to 200.
Give this a try and see how you get on. :)
mrhankey55
mrhankey55
Posted 14 Years Ago
thanks for the help.
i have to say the support response is making me sway to purchasing the product.
one thing though.   say you did make it in 2 or 3 different projects for a movie does crazy talk put it together or do you jjust use movie maker or something?
also if i purchase the product and use it for my anitmations.  do i own the rights to it or does crazy talk have some hold over me?
thanks again
Posted 14 Years Ago
CrazyTalk Animator doesn't contain video editing features itself so you would output each scene from CTA to video and then edit them together. Movie Maker is perfectly usable for this process as is any other video editor you may have.
And any movie you make with CrazyTalk Animator is yours entirely. Be it for private or commercial use, you have complete rights to any videos or still images produced. Plus any content packs you may buy for use in your movie are royalty free for video or image use. So you don't have to worry about any restictions on the use of content.
mrhankey55
mrhankey55
Posted 14 Years Ago
thanks for your help.  i will try learn some more using the trial and hopefully i can get to grips with it and purchase it.
the content packs i can use you say for commercial use if i want?
also looking at the starter kits, do they come with characters?  for example this:
http://www.reallusion.com/contentstore/promo/iClone_Starter_Kit/
looks like it comes with motions but not characters, what one would be best for characters and backgrounds pack?
looking at a more 2d cartoon style.  but like 3d also.
many thanks again
Posted 14 Years Ago
mrhankey55 (7/7/2011)
Yes all content packs sold through Reallusion are royalty free. This means any video or images you create can be used for commercial purposes.
The pack you link to above is for iClone not CrazyTalk Animator. These are two separate programs. iClone works in 3D and CTA in 2D. For CrazyTalk Animator characters please take a look HERE.
Also if you are thinking of purchasing several packs then you may be interested in the Power Tools bundles 1 to 3. These contain a variety of content to get you started without needing you to create your own.
