Issues importing content from Illustrator CS4
Posted By gregory.houston 13 Years Ago
gregory.houston
gregory.houston
Posted 13 Years Ago
Last Active: 13 Years Ago
Posts: 37, Visits: 112
Hi, I've created a character in Illustrator CS4, and am exporting the body part sprites as swf files. When I import those files into the sprite editor, the majority of them have parts missing, and there are strange artifacts showing up.
If I view the swf files standalone, the files look like they should, so the issue is in how they are being imported into CTA.
Has anyone else ran into this issue and found a solution? Is there a setting that needs to be changed in the swf export settings perhaps?
Notice the dotted line artifacts in the attached picture.
TrezSoft
TrezSoft
Posted 13 Years Ago
Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)Senior Member (369 reputation)
Posts: 22, Visits: 611
Hi,
I use CS4 with the following output settings
Export As: All Layers to SWF Symbols
Version: Flash Player 9
Compress File: Checked
Curve Quality: 10
If you still have no joy send over a sample and Ill take a look if you want.
Stuart
gregory.houston
gregory.houston
Posted 13 Years Ago
Thanks Stuart. You've been a bunch of help.
I had "Export As" set to the default, "AI File to SWF File" rather than "AI Layers to SWF Symbols".
I think that has fixed my issues.
13 Years Ago by gregory.houston
AverageJoe
AverageJoe
Posted 13 Years Ago
Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)Distinguished Member (10.7K reputation)
Posts: 2.4K, Visits: 10.1K
Does anyone know of a way to export a single Illustrator file, with multiple layers where each layer could/would be an individual swf file?  For example, an AI file with 5 layers, in a single export option there'd be 5 individual swf files, anmed the same as the layer?
kurzal
kurzal
Posted 13 Years Ago
Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)Distinguished Member (5.9K reputation)
Posts: 627, Visits: 10.4K
wizaerd (7/7/2011)
You can use this script (see attachment). I asked my son and he rewrote an existing script a bit Smile
Unzip and drop it in ...\Program Files\Adobe\Adobe Illustrator CS4\Presets\en_US\Scripts\
Then (in AI): File -> Scripts -> Layers to SWFs
Each layer will be saved as separate swf-file with corresponding (layer's) name in a folder were original file is.
Hope it helps Smile
Igor
Layers to SWFs.zip (202 views, 1.00 KB)
AverageJoe
AverageJoe
Posted 13 Years Ago
Thanx, I'll give that a try... Hopefully it'll work with CS5 as well..
[EDIT]
Works well in CS5 too... thanx!
13 Years Ago by wizaerd
CreativeSoulTV
Arrow
CreativeSoulTV
Posted 10 Years Ago
Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)Senior Member (400 reputation)
Posts: 75, Visits: 506
Do you know if the script will work in version 15.0.0 of CS5? Because I'm getting some errors, see the attached files.
Thanks for any help,
Will
_____________________________________________________________
CreativeSoulTV.com • Video Maker • Cartoonist • Geek • Flawed Genius • Blogger • Tech Enthusiast • Apple Fan • Youtuber • Podcaster • Movie Lover! Cool Social: The Creative JournalCreativeSoulTVTwitter
10 Years Ago by CreativeSoulTV
