davidlingenbrink (6/3/2011)
The weird thing is that when I right mouse a video into the preview window in a clear area (and chose plane), the video only plays in the upper left corner of the new plane. In other words, even when I have a mapped plane, an inserted video (even a sample video supplied with iclone 4) only appears in part of the mapped plane, with blackness in the remainder.Certain graphics hardware may require that textures be in a power of 2 in both dimensions to work with iClone as video textures.
So this means 1, 2, 4 , 8, 16, 32, 64, 128, 256, 512, 1024, 2048, 4096 etc are acceptable. The textures also don't normally have to be square but should be power of 2. So 1024 x 512 will be fine also.
So what can happen is that if you use a video of a standard size like 640 x 480 it will be converted to a video texture of say 512 x 512 to maintain the power of 2 structure. When your hardware doesn't handle this you can get problems like you are experiencing.
Try converting or use a video that is already power of 2 and see if this makes a difference. This will at least eliminate this as being the cause of the problem.
Also make sure you have your graphics drivers updated to the latest available.
