Gentlegiant783 (4/27/2011)
is there any way to alter the feet and toes the way that you can the fingers on the handsOne way requires 3DXChange to export the feet mesh and an external program that can warp the mesh. ZBrush is expensive and difficult to use but many of us use it for these jobs. There are other sculpting programs for free that I'm sure folks can recommend.
However, there is a much simpler, free way to do this within iClone: attach Props objects to the feet, converting the props into accessories.
If the 3D blocks in iClone are not organic enough, or assymmetrical enough, you can build a custom object with the neat freeware Organica. You would still need 3DXChange to import those into iClone, however.
The fact that the toes can't be individually animated gives you a lot of latitude in changing the feet. On the other hand, if you added toes as accessories, these could be animated.
General Picture - animating now to life itself(tm)
Member of Content Wizards
