Iclone and on2 VP6 Codec Issue
Posted By MrAddy 14 Years Ago
MrAddy
MrAddy
Posted 14 Years Ago
Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)Junior Member (186 reputation)
Posts: 1, Visits: 35
Hi,
I need some help trying to import a FLV file into iclone. I have removed the green screen from behind the subject in After Effects. Seems to works okay, but when I try and drag it into iclone I just get an error stating the codec is not recognised.
I have AIR installed and I can view the FLV movie which I thought was all I needed to do for it to work with iclone.
Can anyone help me with this?
I did try PopVideo, but it kept skipping frames and the sound and video never sync. So trying After Effects to remove the green.
Thanks in advance.
Addy
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi Addy
If you wish to use a video with a transparent background then you will need to make a separate alpha channel to go with it. Once you have both videos prepared you add the main video to the Diffuse and the alpna channel video to the Opacity. You will probably find it best to use AVI or WMV for this method.
My personal choice would be to use popVideos. I understand you have had skipping and sync problems but this may be down to the source video used. You would not normally expect to get such problems using popVideo Converter. If you try converting it to a different format you may avoid those issues.
