Iclone 4.3 Error CRC
Posted By haptek 14 Years Ago
haptek
haptek
Posted 14 Years Ago
Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)
Last Active: 13 Years Ago
Posts: 8, Visits: 166
Here is my problem. For 2 days, I make the download, of Iclone 4.3, is when I make the installation, Here is the message!! Impossible of used Iclone 4.3. What is to be done? Thank you has all as your help:w00t:
"" CrC error: The file C:\Program Files\Reallusion\iclone 4\RLVnsRepackerUT.dll doesn't match the file in the setup's.cab file. The medium from which you are running the setup may be corrupted; contact your software vendor.
planetstardragon
planetstardragon
Posted 14 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
i've gotten those errors with ofter downloads outside of RL, in my other cases it had to do with the way the download software was calculating the sums of the packets vs the server.... i once actually helped a developer fix a bug with his software from such an event ....
first thing I would try , is first make sure all my local non rl software is upto date , like java / flash etc ...as some of these downloaders depend on those being up to date ...then I'd clean my cache as some software try to pick up where they left off ..instead of starting a fresh download , so instead of starting a fresh download they just give you the corrupt download over and over, until its deleted and has to start a new file.
and perhaps try a different way of downloading , ie different browser to make sure it's not something going strange in your browser itself thats causing it.
Good luck.
"To define Tao is to defile it" - Lao Tzu
Posted 14 Years Ago
Posts: 23.1K, Visits: 36.6K
Hi..
Sorry to hear of your problems installing iClone4.
As the error message states it sounds like you have a corrupt installation file. I would try and download again and see if this solves your problem. You can login to your account and find the link to download again there. If this doesn't work then please contact Reallusion Support using the link below. They may be able to supply you with a different link to the installation files or advise you to the cause of the problem.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
Note: If you are trying to install the iClone EX version then there is an alternative download link HERE which you may like to try. For purchased versions of iClone please contact Support.
haptek
haptek
Posted 14 Years Ago
Dear Friend Stardragon, thank for your help.
Here is ' Setup ', it is whole, but I do not see other ' Setup ', different, for Iclone 4.3. Here is the identity of Setup, and MB. I am again going to make try, and to follow your recommend. Again thank you sincerely.:)
1)InstallScript Setup Launcher
2) Society: Acresso Software Inc
3) Version 16.0.0.400
4) 219 MO
haptek
Smile
haptek
Posted 14 Years Ago
Dear Peter, I am going to follow, your help, I hope that it will be able to work, with Setup, program makes start, and he makes one stop, just in the beginning, with the message which I show you nowadays, he has a contents it, in Setup, that does not want to make the installation. ' CAB ', where necessary information, has registry. Thank you again Peter, for your help. :)  I hope see Iclone soon.
[quote][/quote]
