A crash followed by inability to run iclone
Posted By thebiz.movies 15 Years Ago
safegaard
safegaard
Posted 15 Years Ago
Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)Veteran Member (862 reputation)
Posts: 360, Visits: 984
Yes it could be a heating problem.
If you have any guarantee on the pc and its possible to get it checked by professionals i would do so if i was you.
If it is an hardware problem who aper when the computer have to do real work to the limit it could be just a matter of time before it goes worth.
I run i7 to and it should be no problem at all with that processor. BUT i had to manually update all of my drivers when i got the "brand" new computer.
Best off luck :)
For the love of 3d http://www.safegaard.com
rontarrant
rontarrant
Posted 15 Years Ago
Last Active: 10 Years Ago
Posts: 231, Visits: 571
thebiz.movies (11/29/2010)
I am now crashing about every 5 minutes of Iclone usage.
Intel Core i7-740QM 1.73GHz Processor with Turbo Boost up to 2.93GHz
iClone is, from what I gather, CPU intensive. Makes a CPU work its butt off. Heat, CPU panic, crash. It sounds like a cooling problem to me.
Because this problem escalated over a month, this may be your scenario:
The seal between the heat sink and the CPU may be compromised, perhaps because the heat sink wasn't seated properly. If that's the case, over a month of usage, the heat sink compound would have hardened or cooked off and left enough air between the CPU and the heat sink to cause this problem.
I hope this message finds you and your computer both doing well. I melted a computer once. It wasn't a pretty sight.
If you can, turn down the speed of your CPU and see if that makes a difference. You didn't mention a liquid cooling system, so I'm assuming you don't have one. If turning the CPU down to its rated speed stops the crashing, and turning it back up makes it misbehave again, get a technician to change the heat sink compound (BTW, it's also sometimes called thermal grease, thermal paste or thermal gel and myriad other names).
You might also consider looking into a liquid cooling system to help keep the heat under control. Cranking up the clock on a CPU to almost double its rated speed begs for liquid cooling.
- Ron T.
planetstardragon
planetstardragon
Posted 15 Years Ago
Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)Distinguished Member (24.1K reputation)
Last Active: 4 Months Ago
Posts: 11.5K, Visits: 46.0K
if i was going over your computer, I'd do the following steps,
1 - http://www.piriform.com/ccleaner ccleaner cleans out your temp files, as well as your registry, these may have funky files ....or you 'may' have malware in your system ? ( or possibly failing components , but first check the least expensive route with these tools )
2 - http://www.malwarebytes.org/ scan your system for possible malware
3 - http://www.revouninstaller.com/ they have a free uninstaller, that cleans out better than the stock windows uninstallers, this helps with programs that may be interfering with your normal system function. a corrupt file loaded to memory can cause trouble.
4 - Update your adobe flash software, www.adobe.com
5 - Make sure you have the latest Java version, www.java.com ( open the control panel click Java, click advanced settings, then under "Temporary internet Files" select "settings" then "delete temporary internet files" this will also clear any potential mal functioning java files.
6 - make sure your os is up to date.
7 -If after this you do not see an improvement, you have to start doing testing for any failing components, such as video cards, ram card, hard drive / bad sectors, mother board as mentioned in another post - which a failing bios battery will change / reset the date - usually to the past when it was first created , not the future.
I hope this helps, you have to set a path to troubleshoot effectively ....start with software , after you go down the checklist, then start with hardware.
- one more -
Dust can become a conductor and cause shorts in your computer, if by chance your computer hasn't been opened in a long time, it may be advisable to get a can of compressed air and possibly a vacuum cleaner fitted with a small / appropriate hose if there is are dust bunnies! Be sure to unplug your computer and wait at least 10 minutes for the power supply to lose any charge before you begin to clean, also make sure you are static free, touch something metal ...as static kills computers too. Dust is a major killer of otherwise functional computers, it kills the ventilation and causes shorts...there is a chance, all be it small, that your system may be shorting from dust build up as well. computer components fail and overheat from lack of ventilation as well. Again, it's not likelly, but a dusty motherboard can cause errors as you have mentioned , as well as failing drives.
Good luck.
"To define Tao is to defile it" - Lao Tzu
thebiz.movies
thebiz.movies
Posted 15 Years Ago
Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)Distinguished Member (14.4K reputation)
Last Active: 5 days ago
Posts: 2.1K, Visits: 42.3K
I am now crashing about every 5 minutes of Iclone usage. Seemingly random as theres no particular event/project that is causing the crash. And by crashing, Im talking about freezing up and hard booting the computer. Computer works all day with no crashing in other programs. Ive turned off all the programs that start on boot. Computer is one month old.
6MB Cache
8GB DDR3 1333MHz SDRAM
1000GB (2 x 500GB) 7200RPM SATA Hard Drive
NVIDIA GeForce GTX 460M Graphics with 1536MB DDR5 Video Memory
I'm not the most technical fellow. Anyone have any suggestions as to how I can trouble shoot this issue?
Super frustrated.
thebiz.movies
thebiz.movies
Posted 15 Years Ago
Bigboss (10/29/2010)
Allow me to suggest that since you just change to a brand new PC, you may have a flaky Mother board and/or your Motherboard Battery may be loose or be on a socket that is flaky..:)
That could also explain why your clock was reset, rare but possible... I hope that is not the case...
That idea gives me halloween sized shivers.
Interestingly, I installed Muvizu last night which also installed the C++ and Direct X things (which is what the support reply said as well). Therefore I suppose that could be the fix instead of the changing of the date.
Thanks for the thoughts folks. I will install and run Norton tonight. Then will see whats what (mattress man). Heres hoping this is a non-issue.
Bigboss
Bigboss
Posted 15 Years Ago
Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)Distinguished Member (27.9K reputation)
Last Active: 10 Months Ago
Posts: 3.6K, Visits: 9.4K
Come and visit my store by clicking on the banner below.
https://forum.reallusion.com/Uploads/Images/02c8abe1-c35a-41e0-8640-0789.jpg
duchess110
duchess110
Posted 15 Years Ago
Posts: 2.0K, Visits: 15.5K
Sorry to hear your problems.
With regards 3d Exchange I know at one time that happened to me and also shygirl if I recall.
If I remember correct once I reinstalled the direct x and the C++ stuff it worked fine.
Perhaps Peter if he reads this could confirm that redoing these can help.
Duchess Designs Store
colour
colour
Posted 15 Years Ago
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 5.2K, Visits: 8.1K
thebiz.movies (10/28/2010)
Oh dear...
Uninstalled, reinstalled.  Same error popup.  Havent heard anything from support.  Ideas?
3dExchangeV2 gives me the same error when I try to run it.  I suppose I will try to reinstall that as well.
Update:  Another program alerted me to the fact that my calender was now set to 2093.  I updated the date and now I seem to be able to run Iclone.  Bizarre.  Whatever caused the original reboot seems to have reset my date.  I will test more this weekend to make sure this is indeed the issue and no other problems linger.  Weird eh...
If your Pc's Calender is reset to an earlier or later date, then the  Installation "Date Stamp"  for Installed Programs is out of synchronisation & many won't function correctly, especially those with annual renewals eg; Antivirus Programs etc, when you'll be prompted to Renew the Applicatioin & that the Application License has expired & you can no longer use it.
That, together with your RunTime Error & PC automatically Re-Booting, suggests to me that you have Malware loading at SartUp & "Filling-up" your RAM. Those are well-known classic symptoms of Malware on a PC.
You need to Run both Antivirus & AntiSpyware Full Scans, PDQ.
thebiz.movies
thebiz.movies
Posted 15 Years Ago
Oh dear...
thebiz.movies
thebiz.movies
Posted 15 Years Ago
I figured as much. Wasn't looking forward to another install after just installing it last weekend. Will try to re-install this weekend. Sigh. The troubles of an animator.
