Thank you, folks! I appreciate the responses. At least I can see some options
SJ: I am not very familiar with Actionscript but I'll learn it or find someone who is if that's what's needed. Would you care to elaborate a bit on your suggestion? Any threads or articles that you think may help with this specific requirement? What I'm really after is finding a workaround for the lack of CT webcomponent with its dynamic change of the script functionality (that had been discontinued since v4), which would be ideal for this task and other similar ones (it's a bigger educational project with several stakeholders).
InfoCentral (10/16/2010)
I don't see any advantage to not breaking it up into individual videos. It would make it easier to add content and also when there needs to be changes in the current content. Just make sure you copy the starting key frame to the end of the video and repeat the same key frames in all subsequent videos and it all should play very smoothly. This will become your "master key frame."IC: the advantage is Maintenance. If I ever need to change the model or put it on a different background or create another character with the same script or turn it into a "dragable" popwidget it will be a lot easier to do it once than 20 or 30 times. In my years in IT and software development they used to call it "maintenance nightmare". I've seen it too many times to count. Your suggestion would certainly be the simplest and probably the easiest to implement but it may not fit the bill very well in the long run. For a simple quick and dirty FAQ solution or for demo purposes, yes, but not in this case. Thanks, though.
