Mass scene
Posted By boris.degenhardt 16 Years Ago
boris.degenhardt
boris.degenhardt
Posted 16 Years Ago
Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)Veteran Member (579 reputation)
Posts: 15, Visits: 83
Hi everybody,
im new to iclone and im just trying it out right now. Is it possible to clone (copy + paste) an avatar? If so, is it possible to clone it including its animations? Help would be nice ;)
Best regards
Boris
warlord720
warlord720
Posted 16 Years Ago
Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)Distinguished Member (7.3K reputation)
Last Active: 9 Years Ago
Posts: 1.3K, Visits: 3.9K
There are some things that can't be cloned/replicated including characters and when you clone an animated prop you will have to trigger the animation again as the cloned prop comes in with animation removed until you right click and trigger it again. The clone props animations are still available... just not triggered.
If you haven't cloned/copied a prop before... select the prop... hold down the ctrl key and move the prop. The original will stay in place and the new copy will appear to be manipulated as you desire. No mass replication or scatter is available either. Make sure when cloning that you have the MOVE command highlighted on the top menu and not the PAN control or you'll just pan the camera.
I LIVE to anymate, irritate and machinamate. Not necessarily in that order.
boris.degenhardt
boris.degenhardt
Posted 16 Years Ago
Thanks alot...its worse that there isnt the possibility to clone Characters, for example you want to have 50 footsoldiers that walk in a row!
Best Regards
Boris
Galfridus
Galfridus
Posted 16 Years Ago
Posts: 727, Visits: 2.2K
Hello Boris,
In addition to Warlord`s sound advice above, remember that in Iclone you need to carefully manage the resources used in any one scene to keep things from slowing down to an unworkable level. It`s the trade off for being in real-time. Having 50 fully dressed and animated footsoldier avatars may over tax even the very best high-end systems.
There are work-a -rounds of course. Here are a few examples of tips I've picked up previously from the forum:-
1) Use an external video editor to carefully edit together scenes of just a few soldiers. You can create the effect that a much greater number are involved in your final movie.
2) By substituting a static image of soldiers into the "grass" function you can create a great mass of "background" soldiers who gently "sway" in random fashion. Add a few fully animated avatars in front and use careful camera angles to complete the illusion of a whole army.
3) Create a few popvideos of "animated small groups of soldiers" and use multiple copies of the popvideos to populate your scene.
As you become more familiar with Iclone you will begin to plan your movies to maximise the many advantages and possibilities it offers and at the same time avoid, adapt or "fake" those areas which are more problematic.
Good luck.
Geoff.
https://forum.reallusion.com/uploads/images/ba17ca1f-2bbe-4b61-819c-6bdf.png
shellysummers2000
shellysummers2000
Posted 16 Years Ago
Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)Senior Member (368 reputation)
Last Active: 11 Years Ago
Posts: 7, Visits: 58
Well not clone like you would a wall. You can hit the plus button and that will create a new custom avatar.
Emerald Animation...
Posted 15 Years Ago
Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)
Posts: 334, Visits: 1.1K
I had not thought of your grass or popVideo workarounds ... they are pure genius!  Thanks for mentioning them!
