PTex support
Posted By Dreamcube017 9 Years Ago
Dreamcube017
Dreamcube017
Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)Distinguished Member (7.2K reputation)
Posts: 2.0K, Visits: 2.9K
So this was mentioned in the popeline thread.
It would be great if iClone could support PTex files.
What's PTex?
It's something Disney uses to get super detailed textures. It works by looking at how much detailed is in the texture and then makes more UV space for that spot. So in the end, you can end up with a LOT of UV maps.
A 3D painting program (such as 3D-Coat) can be used to paint this way. That way you aren't limited to how much detail you can put in a map. You can even have a full UV Space for just two or three polygons.
There's more info here.
http://ptex.us/
Now, I don't know if realtime engines can handle this or not, but it'd be a great idea.
I'm also not saying that this should replace current texture methods, but it's an idea.
Any thoughts?
***BEST OF THE CORE**
:A music reel demonstrating the different types of music I produce for multimedia. Hope everyone enjoys.
Player not working? Use this link.
My other audio work.
Facebook page:
Creation begins at the core.
Ascensi
Ascensi
Posted 5 Months Ago
Posts: 74, Visits: 541
It's been a while since this was updated so I'll chime in here why this format is extremely important.
*It would negate the need for Triplanar mode and Anisotropic Filtration, both are very resource demanding, if removed could then actually increase performance for very high resolutions.
*Ptex like Vector graphics is scale-able so in theory we might be able to use smaller sized textures.
*Can work with texture arrays -also a way of increasing performance.
| i7 -4790K 4.0GHz | 32 GB | GeForce RTX 2080 Ti 11GB | GTX 970 x4 | Window10 | Zbrush 2018 & Keyshot | Maya 2014 | Adobe CS6 | Sonar Producer X3 | iClone Pro & 3D Exchange Pipeline 7 | DTS Master Audio Suite | Perception Neuron 32 Alum Edition | Akeytsu
https://forum.reallusion.com/uploads/images/2181b17f-1a5f-4475-a14b-4dbe.gif
Everything here was modeled in Zbrush, Rigged in Akeytsu, animated in iClone 7 and Rendered in Indigo Render 3X   - Fully Noobed, no years of experience, must have vision and drive -completely oblivious to time.
Scene was almost 3 Million polygons. Since it wasn't covered in any tutorials or the manual I learned the hard way..  Set iClone to use quick shader and set any displacement to 0 when exporting to Indigo Project files. Enable any displacement levels in Indigo.
5 Months Ago by Ascensi
