Strange behavior by Jana in a car.
Posted By sascheid 16 Years Ago
sascheid
sascheid
Posted 16 Years Ago
Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)
Last Active: 11 Years Ago
Posts: 17, Visits: 58
Her breasts keep changing size! They go in and out from gone altogether with holes in her chest to gigantic and back again! No, this is not a perverted joke (on my part anyway). Why does it do this? And, more importantly, how do I fix it? For now I'm trying to keep the camera off of them but there is no reason it should be doing this.
sas
Alley
Alley
Posted 16 Years Ago
Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)Distinguished Member (18.0K reputation)
Posts: 3.7K, Visits: 12.8K
With the avatar tab selected, on the right is an area called "Spring".  You can try adjusting the sliders, or just uncheck spring altogether.
Also, if you go to you "Import Setting", go to default folders, there is a folder called "Avatar Setting", where you can select a couple of different "breast" settings.
The path in XP is C:/Documents & Settings/All Users/Shared Documents/Reallusion/Template/Iclone 4 Template/Iclone Template/Avatar Setting
Alley
sascheid
sascheid
Posted 16 Years Ago
Thanks I'll give these tips a try.
sas
sascheid
sascheid
Posted 16 Years Ago
The spring settings did the trick. I'll be checking out the avatar settings later. Thanks for your help.
sas
Posted 16 Years Ago
Last Active: 27 minutes ago
Posts: 15.8K, Visits: 31.4K
There are problems with the breasts when the girl is moving fast. I noticed that with a girl riding a horse and had to turn the effect off. Probably an issue that needs reporting.
Posted 16 Years Ago
Posts: 23.1K, Visits: 36.6K
zuijlen (7/12/2010)
I'll pass this on to the iClone team to check for future enhancement (no pun intended).
Thanks for the feedback. :)
