Fix holes in clothing mesh?
Posted By Auroratrek Last Year
Auroratrek
Auroratrek
Posted Last Year
Posts: 224, Visits: 1.2K
Hi, I got these weird holes in my imported clothing mesh after I did a Smoothing operation. Is there a recommended way to fix holes in a clothing mesh?
https://forum.reallusion.com/uploads/images/cae5bdbc-03bf-430a-8cc9-7adc.png
On my Youtube Channel: Quest of the Key: Chapter One
Posted Last Year
Last Active: 11 days ago
Posts: 5.3K, Visits: 16.8K
I cannot make much from that picture (needs to be in wire-frame mode - before and after to be sure).
But if you say the mesh is getting ripped with sculpting/smoothing, then it means mesh was already ripped when imported.
Happens a lot when 2 vertices occupy the same space and not joined together.
What you can do, is to go Mesh>Weld Vertices, specify a relative distance between vertices (0.01 is good enough for "perfectly" spaced double vertices) and click Merge.
But do it right away upon importing an object.
Auroratrek
Auroratrek
Posted Last Year
Hi, thanks for the tip. Unfortunately, the clothing mesh has morph sliders that welding will apparently eliminate. It's still good to know for other items.
sunlikevoid
sunlikevoid
Posted Last Year
Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)Senior Member (347 reputation)
Posts: 17, Visits: 436
It looks like your mesh is two-sided, and the inner mesh is poking through. Go to edit mesh, select faces, click the part poking through, then use W to push it back in.
