flo.zauner (11/13/2024)
Yes I noticed that already, however switching between the modes does exactly nothing. Object related helps in some cases, however most of the time I need more than one object at the same time BUT without a million tracks that I do not animate. The timeline is customisable so you only see the information you want. The screenshot below shows the areas where you can toggle on or off everything in your project. When combined with the two buttons previously mentioned, you should be able to display just want you want to work on.
You mention you have only been trying out CTA5 for a couple of days. It is quite common for all of us to feel frustration or disappointment with software that has quite a steep learning curve as we all want to be productive straight away.
I would advise spending time with the tutorials and webinars below which cover all the features of CTA5 including the timeline. If you start with the basics and gradually increase to more advanced features, you should find it all starts to come together quite quickly.
https://courses.reallusion.com/home/cartoon-animator
