Weird triangled faces on cloth imported from Marvelous Designer
Posted By MbareJack 2 Years Ago
MbareJack
MbareJack
New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)
Posts: 2, Visits: 52
Hello everyone,
I've done this roman toga cloth for a character in Marvelous Designer, then I've imported it in Blender to optimize it, reducing number of polygons, made the Uv's, setting face normals, cleared custom split normals data, recalculating outside, smoothing faces, removed sharp edges and everything possible but I still having this weird effect on it.
All polygons are squared and vertices are merged, all faces are oriented correctly and I really can't figure out what's wrong.
Please is there someone that can help me to solve this issue?
Thank you
https://forum.reallusion.com/uploads/images/4921e7e5-a97a-4638-8990-0f36.png
https://forum.reallusion.com/uploads/images/34e85827-a6f4-40ae-a9e9-6f35.png
https://forum.reallusion.com/uploads/images/9423dc56-4218-4f17-9820-30c9.png
https://forum.reallusion.com/uploads/images/696e6bda-eee1-4807-8df8-174d.png
https://forum.reallusion.com/uploads/images/0a39c92d-309b-498d-8659-b71f.png
as you can see the reflection on some polygos are incorrect and it seems that some faces are still triangles even if they're not...
Last Active: 7 days ago
Posts: 5.3K, Visits: 16.8K
...cleared custom split normals data...
Are you sure? Blender shcreenshoot kind of indicates that it's not cleared.
Try Auto Smooth in CC: Mesh > Edit Normals from the menu. Set relatively high angle, like 180 (you do not need any sharp edges there).
Also, how did you export from MD?
Those are optimal settings to save you from all kind of problems:
https://forum.reallusion.com/uploads/images/177a09f6-b97c-42a8-b0b0-e545.jpg
Finally, Soft Shadow on certain light schemes in CC gives weird shading artifacts.
Lower it down and see if it does change anything.
(Shadow Bias and Resolution might also affect that)
https://forum.reallusion.com/uploads/images/205bba39-b63a-4f05-b413-fde4.jpg
MbareJack
MbareJack
Thank you for answering me so quickly!
I've cleared normal and added many times but it seems nothing changes
https://forum.reallusion.com/uploads/images/4f80e188-722d-4694-88bb-fc34.png
Cleared
https://forum.reallusion.com/uploads/images/389d4c5f-473b-4976-98fd-335c.png
Added
I've exported in Fbx format from MD but also tried with obj with the same settings that you have
https://forum.reallusion.com/uploads/images/7db75f60-09b2-4c1d-a1f4-9bbc.png
The autosmooth in CC doesn't change
https://forum.reallusion.com/uploads/images/a4526e11-2aad-47fd-bbf6-ff05.png
I've tried the light settings that you suggested me and something changes a little bit but of course it loses quality and seem that the best result is to switch off the soft shadow
https://forum.reallusion.com/uploads/images/5567da90-7781-4478-a45f-f707.png
Soft shadow reduced quality
https://forum.reallusion.com/uploads/images/124e4c9a-ebb1-45ac-8af0-d3a3.png
Soft shadow switched off
it seems that the shadows improve the situation a bit at the expense of quality.
However, I don't know if it's resolved or it's like we've put some sort of patch on it...but do you think it depends on the geometry or is it purely related to the lighting?
Thank you for your support
