Character Creator 4.5 - New update
Posted By HansRL Last Year
HansRL
HansRL
Posted Last Year
Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)Veteran Member (860 reputation)
Posts: 29, Visits: 211
v4.5 (4.5.3325.1) released on Sep. 26th, 2024
Several bug fixes.
Fixed:
  • OV Connector does not support CC 4.5.
  • Syncing the Smart Content Manager causes an AP crash. Feedback Tracker
  • After updating a character with Face Tools from ZBrush back to CC, the character's head disappears. Feedback Tracker
  • After generating the head using Mesh mode in Headshot 2.0, the mouth opens and the mesh sticks together. Feedback Tracker 1, Feedback Tracker 2
  • When exporting FBX with "Bake Diffuse maps from skin color" checked, and loading it into any 3D software, only the head has the baked Skin Color applied.
  • Because the Actor under the Reallusion Custom Content folder does not have Avatar Control, it is unable to create a ccSlider. Feedback Tracker
  • Hair or Motion files larger than 100 MB cause AP to crash during loading. If these files are in the Custom folder, they also cause the Smart Content Manager to crash during data syncing. Feedback Tracker 1, Feedback Tracker 2
  • Applying a hair-type iAcc/ccAcc to a character and scaling the Camera view causes the hair to appear or disappear with the zoom. Feedback Tracker
  • The "Enable DLSS" setting in the Preferences panel is not being saved. Feedback Tracker
  • When DLSS is enabled, the Grid will be rendered if it is turned on.
  • When DLSS is enabled, switching Final Render settings to Medium or High and then rendering causes AP to crash.
  • After entering Proportion, switching to Full Body and adjusting the Scale value, exiting the mode causes an AP crash. Feedback Tracker
  • When the Creature character uses AccuRIG and executes the Bind Skin process, it causes an AP crash.
  • Threaded View
    Threaded View
    Forum Post Character Creator 4.5 - New update By HansRL ( Last Year )
