Size limitation when importing motion FBX files
Posted By eastsky 2 Years Ago
eastsky
eastsky
New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)New Member (86 reputation)
Posts: 5, Visits: 23
Hello,
I'm working with motion capture data from Xsens and using the iClone 8.5 trial version. I’m encountering issues when trying to import larger FBX files. Specifically, when I try to import files larger than 30MB or with more than approximately 85,000 frames, iClone crashes during the import process.
Could you please clarify if there’s a size or frame limit when importing motion capture data into iClone, or if there are any recommended solutions?
Thank you in advance for your help!
Kalex
Kalex
Posts: 602, Visits: 6.5K
I had a similar issue  but with Perception Neuron. Never had a problem before, only this tipe the file was more than 30mb. Iclone crashed everytime. Only solution I found waa to export the raw animation from Axis Neuron in 2 clips, cut in half. It worked this way...
Last Active: 4 days ago
Posts: 8.2K, Visits: 62.6K
Please try increasing the frame-count of the timeline in the Project panel.
eastsky
eastsky
Thank you for your suggestion.
I tried it, but the issue remains the same.
When I drag and drop the large animation FBX into an empty space in iClone, it works fine.
However, if I drag and drop the same FBX onto the motion dummy in iClone, the program crashes.
Without the motion dummy, it seems I can't utilize the IK mode in Edit Motion Layer.
Kalex
Kalex
what mocap software are you using ?
eastsky
eastsky
I'm using MVN Animator Pro from Xsens, so when I import the data, I select the 'xsens' option.
Posts: 5.3K, Visits: 16.8K
Try different approach.
Instead of drag/drop, do not select any character and use Import > Convert External Motion from the menu.
It would convert and create a motion in the designated folder only.
If it does not crash, try to apply created motion to a character then.
eastsky
eastsky
Thanks for the suggestion.
I confirmed that when I converted the animation FBX, it was successfully saved without crashing in the C:\Users\Public\Documents\Reallusion\Reallusion Custom\Animation\Motion\External Motion folder.
However, as soon as I assign the saved .rlMotion file to the motion dummy, iClone crashes immediately.
Kalex
Kalex
eatsky I don't know xsens, as I'm only using Axis Neuron. Do you have an option that allows to export the motion clip in 2 clips, each one being the approximate half ?
eastsky
eastsky
Of course, the file can be split into two clips, and in that case, it works perfectly. However, I’m reviewing iClone specifically to handle larger files in one go. Personally, I don’t consider 26MB to be particularly large.
FYI, the 26MB figure comes from my testing when I split the file and found the point at which it starts to work properly.
