inessenzialeart
inessenzialeart
Posted Last Year
Visits: 37
Hi, I just installed CTA5.3 but I'm struggling with custom animations. In small words, whenever I save a custom animation in order to reuse it in a second moment, it says everything is ok, but when I apply the animation it seems that nothing has been actually saved. All of the custom animations I created with versione5.2 work perfectly even in this version. Can You give me some feedback about this problem? Is there some new feature that I don't know about custom animations? Thank you for you support, have a nice day Simona :)
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
Hi Simona As there are various types and ways to save animations, please can you let us know the steps you take leading up to the issue so we can try and reproduce the problem. Thanks.
inessenzialeart
inessenzialeart
Posted Last Year
Visits: 37
Hi Peter, thank you for your answer. Yesterday I posted the same problem in the feedback tracker, because I didn’t know exactly where to post this issue, and they replied me today, so I sent a video in which I try to save a simple animation I made for a prop, together with the cta project. I apologize if I made a mistake posting the same issue both here and in the tracker, however in simple words this is the problem: I make simple changes to a prop and when I try to save these changes collecting the keyframes in order to use them as animation or as action, it seems that it ddid'n record anything, when I recall the action or the animation. All of the animations I saved within CTA 5.2 still work perfectly. Thank you again. Simona :)
Posted Last Year
Posts: 23.1K,
Visits: 36.6K
Hi Simona If at anytime you believe there is an issue with the software, reporting it in the Feedback Tracker is the right thing to do. Now that the dev team have your project file they will be able to test to see what the problem is and will give you an update there.
