AccuRIG -> ActorCore -> iClone 8
Posted By DRLarkin1776 2 Years Ago
DRLarkin1776
DRLarkin1776
Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)Veteran Member (622 reputation)
Posts: 54, Visits: 280
I've rigged 2 characters via accuRIG.  Worked great.
I uploaded to ActorCore.  They show up in ActorCore when I go to the "Uploaded Actors" section.
I had assumed that uploading them to ActorCore would make them available in iClone 8 and CC4.
However, I don't see them there.
Am I misunderstanding how this works?  The point of rigging these characters was to use them in iClone.  How do I get them there?
Also, if I wanted to adjust the rig after uploading the character to ActorCore is there a way to to pull it back into AccuRIG?
Thanks!!
--DRLarkin
K_Digital
K_Digital
Posts: 327, Visits: 1.4K
As far as in know you can only adjust the rig in CC.
First export your char from acccurig as iavatar on disk, then import it into iclone or CC.
You can also edit your char via  -edit in Charctaer Creator"- in iclone on the modify panel.
