Peter (RL) (7/2/2024)
Hi...
This is a strange one. I've never encountered an issue like the one you show and still can't reproduce it now in 8.42.
Do you have any python scripts running?
Also are you using a 3D controller or similar device? If you are, try disabling and just use a standard mouse and keyboard to see if the problem is still there. It would also be wise to completely shut down your computer then restart to see if the issue stops.I don't have any python scripts running.
After a reboot, I disconnected all USB devices, apart from standard keyboard and standard mouse.
Ran iClone8 again and the problem was gone. So it does seem as though one of my USB devices was short cutting on the Move transform areas. Is that possible to interface USB devices to this dialogue area? And if so, is it possible to disable that function so that I don't get this again?
