michael7
michael7
Posted Last Year
Visits: 1.2K
Please note I am using iclone 7 and not 8, but I'd still like to see this problem resolved. If you create a cube, and make it 15 inches ( just as an example because that's what I am doing ) and then create a cylinder at the same measurement, 15", both objects will be the same size, along all three axis. But if you then change the scale of the cylinder so it stays the same in height, 15", but change the size on the x and y axis, to 7.5 for instance with both ( which is what I am trying to do ), the cylinder - VISUALLY, is no longer at the same height as the cube, it is longer, even though the scale says it's still 15". This has been driving me nuts trying to figure out what is going wrong.
