Zbrush pose link fail
Posted By bluesexperience1969 4 Months Ago
bluesexperience1969
bluesexperience1969
Posted 4 Months Ago
Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)Junior Member (122 reputation)
Last Active: 4 Months Ago
Posts: 1, Visits: 2
I installed the latest version of zbrush(2024.0.4) and character creator(v4.42),then i followed the guide and install the zbrush pose tools and zbrush pose link(v1.01). When i opened zbrush and goz a mesh into CC, it warns me that i'm not using "CC GOZ Plus" plugin so the diffuse map and normal map will not be updated, but the mesh did went into CC, but when i tried to goz it back to zbrush, a series of warning pops up. At first it tells me to close zbrush so it will automatically install the CC GOZ Plus plugin, Then it says the diffuse map and normal map can't be located, finally the whole processe failed due to "data processing in zbrush", i'm supposed to waite or click the "restart CC GOZ plus" button in the zbrush CC GOZ plus plugin which i didn't find in zbrush plugin menu. I tried a several times, this one time zbrush also pops up an error, i don't know what it means but it seems like it's related to the CC GOZ plus plugin.So please informe me which step i went wrong?
https://forum.reallusion.com/uploads/images/9fdbad82-b3c8-4442-a500-32d7.pnghttps://forum.reallusion.com/uploads/images/1a00c920-7bc0-4c7c-989c-f459.pnghttps://forum.reallusion.com/uploads/images/90b8534b-dd2f-46ae-b9dd-604e.pnghttps://forum.reallusion.com/uploads/images/25c4cf4c-0a64-447e-8319-4faf.pnghttps://forum.reallusion.com/uploads/images/dccbcd1d-9168-4d27-9fec-36e1.png
massimorossa
massimorossa
Posted 4 Months Ago
New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)New Member (3 reputation)
Posts: 1, Visits: 6
I've the same problem. Did you find a solution?
dramzii23
dramzii23
Posted 4 Months Ago
Posts: 1, Visits: 2
x 2.
Facing the same issue.
Posted 4 Months Ago
Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)Distinguished Member (122.7K reputation)
Posts: 23.1K, Visits: 36.4K
If you are still having problems, please contact Support using the link below. They will help you with this issue.
shavonne.w
shavonne.w
Posted 4 Months Ago
Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)Junior Member (125 reputation)
Posts: 6, Visits: 106
Similar issue, unable to finish my round trip from Zbrush back to CC.
Given how much CC costs, the speed of responses from them on this sort of issues is honestly way too slow..
ChengJhong(RL)
ChengJhong(RL)
Posted 4 Months Ago
New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)New Member (8 reputation)
Posts: 3, Visits: 34
Please check if folder CCGoZData and file CCGoZ.zsc are under C:\Program Files\Maxon ZBrush 2024\ZStartup\ZPlugs64 (Default zbrush 2024 install path). If not, please copy from <path to chraracter creator>\Character Creator 4\Resource\ICGoZBrush\ZBScript to ZPlugs64.
CC GoZ Plus will be under Zplugin.
https://forum.reallusion.com/uploads/images/c355c29c-da7b-48c5-9d70-ba7f.png
ChengJhong
Reallusion
ChengJhong(RL)
ChengJhong(RL)
Posted 4 Months Ago
If zplugin exist, please check if you have any zbursh that has been removed but still in registry. Currently, the registry of zbrush that doesn't exist have to removed manually.
It should be under HKEY_LOCAL_MACHINE\SOFTWARE\Maxon\
