Possible to interact with Collect Clip in Timeline?
Posted By dan.goyette Last Year
dan.goyette
dan.goyette
Posted Last Year
Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)
Posts: 83, Visits: 379
I'm pretty sure the answer is "no", but maybe I missed something.
I'm trying to automate the creation of animations. The most cumbersome part is manually drag selecting the Collect Clip bar to choose a frame range. For example:
There appears to be no way to set the start/end to a given frame, other than dragging and hoping you do it right. I was hoping the API could help me either to:
  • Programmatically set the Start/End of the Collect Clip.
  • Trigger the "Add MotionPlus to Library" action on the selection.
I don't see anything promising in the API, but I wanted to ask. I'd also be very eager to hear any other approach I might take to exporting multiple clips from the Timeline.
Thanks.
Posted Last Year
Posts: 5.3K, Visits: 16.8K
Not sure about API, but you still may do it with frame precision.
It's a bit tricky at first, but easy to get used to.
https://forum.reallusion.com/uploads/images/dac7c51b-5c91-4b1a-ad2a-b8d5.gif
dan.goyette
dan.goyette
Posted Last Year
Yeah, that's what I'm currently doing to export motions. Doing it once is no big deal, but having to do this once per motion, every time I change something, gets pretty slow and tedious. I was ultimately hoping I could use the API to auto-set the start/end range of the Collect Clip track based on the currently selected clips. But it just doesn't seem like the API has much/any Timeline interaction.
