sunnyviewtech
sunnyviewtech
Visits: 473
Using default settings of the software, without pre-calibration The software used, Apple ARKit: LIVE Face NVIDIA Maxine: Reallusion AccuFACE Google MediaPipe: Dollars EGAO
Nirwana
Nirwana
Visits: 1.5K
Interesting comparison. My take: - None of the three are really good with default settings; they all need quite a lot of tweaking and/or better calibration. - To me, a blend of LiveFace and AccuFace would probably look best. The mouth on LiveFace sometimes looks exaggerated while AccuFace wrinkles the forehead a bit much. - The Dollars EGAO version (never heard of that) looks the worst to me; the eye lids look far too sleepy and the facial motion too sedated considering the emotional delivery of the voice actress and her wide open eyes. - There are two things I found problematic with the test/comparison itself: (a) a male avatar for a female voice (b) that no head rotation was applied to the avatar. I assume this was done to more clearly compare the facial details of the capture, but to me it looks distracting (also if she tilts her head but still looks at the camera, can the facial capture reproduce that accurately?). So I'd like to also see a version with a female avatar and head rotation included.
My YouTube channel: Animations made with Cinema 4D and Reallusion Products
R Ham
Last Active: 4 Months Ago
Visits: 4.1K
The iPhone works well enough, but the teensy screen is unfortunate. I've never been able to get AccuFace to run properly. Much facial distortion, lips tied in knot. Dollars wasn't functioning at all last time I looked, I guess they fixed it.
All in all, the iPhone is my choice of the three. It's worth mentioning that the iPhone is not able to raise one eyebrow individually. I've brought it up more than once. I suspect AccuFace has some host setup requirements that have not been documented. The marketing vids all look swell.
Facial mocap is a great idea but, in the past, it has lacked a professional implementation.
"Less clicks good, more clicks bad."
AutoDidact
AutoDidact
Last Active: 11 hours ago
Posts: 2.1K,
Visits: 13.6K
From my experience using Facial capture and watching many UE5 metahuman/Iclone videos (where various facial capture apps were used) It seems (to me at least) when you try to capture head movements/rotations you always get an uncanny, very linear “Theme Park Animatronic Robot “ look to the head movement.
I think this may be a limitation of the video based capture solutions thus far and is the reason I would never pay for one.
We have a free video based solution for Blender called “face landmarker” The best scenario is when you have both a good facial animation control rig and or shape key animation panel to manually tweak the expressions based on the emotional tone of the actors performance and the ability to bypass head rotation recording and manually key frame subtle head rotations on top of the facial capture.
Here are some of my recent tests using an AI generated facial lipsinc as the video source with the free Live link CVS importer for Blender on a Daz genesis figure which comes with the 52 Arkit facial facial Blend shapes already built in.
And another using a video of a real person as the source
Neither are “ Thanos Endgame Level” shots obviously, and need more refinement .:blush: Still, for a FREE SOLUTION, I don’t think they too far off from the recent video based solutions that cost hundreds of dollars not including the mandatory modern NIVIDIA RTX card (Like Accuface)
Visits: 22.1K
R Ham (4/3/2024)
I've never been able to get AccuFace to run properly. Much facial distortion, lips tied in knot. I suspect AccuFace has some host setup requirements that have not been documented. The marketing vids all look swell.
As I've asked to more than one person, can you just post a sample video of what you are using that doesn't work for you? I've had no trouble with Acculips at all (and prefer it to LiveFace - not by a wide margin but perhaps 10-15% better and, of course, MUCH easier to use recorded video from other sources with, although as I've shown you can do it with LiveFace as well) but I'm pretty sure anyone's issue with Acculips can be tracked down if they are willing to either share what video they are using OR use a standard video someone else is. I haven't tweaked the settings at all (now - part of it might be due to what video card/drivers are being used, but until someone shares their problems it's hard to help). Since I've now bought four facial animation solutions in the past decade or so I have to say I'm really impressed we can do it so easily now (those of you who used some of the primitive ones in the past - including ones you had to put markers on your face (ugh) - have no idea how sophisticated the ones we have now are).
R Ham
Visits: 4.1K
Below is an example of what I got with AccuFace. I finally assumed there were some default iClone settings that were required for AccuFace to work properly, and that I had altered them during a "press every button" session. If I had seen a "Reset all relevant settings to default" button, I would have used it. I did fiddle with the settings as best I could. I could get it to a point where the mouth looked normal when it was closed, but not when it was moving.
R Ham
Visits: 4.1K
AutoDidact (4/3/2024)
[quote]Here are some of my recent tests using an AI generated facial lipsinc as the video source with the free Live link CVS importer for Blender on a Daz genesis figure which comes with the 52 Arkit facial facial Blend shapes already built in. The first test in the first vid is the best. The second test in the first vid can't quite get its lips closed between words. Why the difference? The second vid suggests that only one brow is being monitored. That seems odd. If animation is imported, there's no need for face tracking at all. Does this plugin allow the movement upward of a single eyebrow?
Visits: 22.1K
R Ham (4/3/2024)
Below is an example of what I got with AccuFace. I finally assumed there were some default iClone settings that were required for AccuFace to work properly, and that I had altered them during a "press every button" session. If I had seen a "Reset all relevant settings to default" button, I would have used it. I did fiddle with the settings as best I could. I could get it to a point where the mouth looked normal when it was closed, but not when it was moving.  So what video were you using? Without that we can't accurately help you (if we can standardize on what we are using we can track this down).
R Ham
Visits: 4.1K
Kelleytoons (4/3/2024) [quote] So what video were you using? Without that we can't accurately help you (if we can standardize on what we are using we can track this down).Ah, what video source. The source was a live webcam. A Logitech Brio.
AutoDidact
AutoDidact
Posts: 2.1K,
Visits: 13.6K
Well if you look carefully at the source video being tracked the guy is a bit of a “mouth breather” and leaves his mouth open alot between words.
The blond lady video source is an AI generated talking head I made last year.
I think you misunderstand my process this is not “live” face tracking recorded in realtime you (or some remote actor) records a video and the face landmarker app basicly detects and tracks the face motion and saves a “CSV” file that is imported into blender and applied to a genesis figure via the free Diffeomorphic addon.
I Believe Accuface does similar with pre-recorded video sources ..yes?? however it does not restrict me to Daz or any figure ecosystem as it works in Blender with any rig that has the 52 ARKIT blend shapes such as the free avatars from the “Ready player me” website
That said it comes with a secondary panel that does have a Live face tracking option but I cant be bothered to set up the connection with my Android phone as I prefer a curated video sources and don’t do any live streaming online etc. Does this plugin allow the movement upward of a single eyebrow?
If the actor in the source video does a single “Spock like” eye brow raise then yes this app will record it into the CSV data However capturing such subtleties are moot for me as I am one who considers ALL mocap to be a base layer starting point where you should always have the option of layering one top with discrete non destructive layers via a viewport control rig for body and face.
