How to consistently export a portion of the Timeline?
Posted By dan.goyette Last Year
dan.goyette
dan.goyette
Posted Last Year
Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)Veteran Member (825 reputation)
Posts: 83, Visits: 379
(First, I'm open to suggestions for a different workflow for how I'm approaching this...)
I'm setting up several (hundreds, eventually) distinct Lip Sync animations using AccuLips. So far, the only slightly viable way of approaching this (and still being able to edit things if I need to make changes) is to stack them all up on the Timeline, then use "Collect Clip" to select a range, and saving it to a MotionPlus library. For example:
Although this works, there's an annoying problem: I have to manually eyeball the "Collect Clip" start/end point.
Is there some way to get a consistent start/end when saving as a MotionPlus animation? I know I can set the timeline's Playback start/end to match the Expression I'm using, but Collect Clip doesn't care about that. Ideally there would be some way to "label" a portion of the timeline, and save that range as a MotionPlus animation.
Anyone have any ideas?
Threaded View
