Problem Realtime rendering
Posted By ivan.g Last Year
ivan.g
ivan.g
Posted Last Year
New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)New Member (17 reputation)
Posts: 2, Visits: 23
Hi,
My project is not smooth when I move in my 3d space when "Volumetric light + Environment reflection + Shadow map" are activated in my preferences. It is strange because  my project is using only 7.4 Gb out of the 24Gb of my graphic card and is using 6% of the cpu... I don't understand why it is so shacky whith more than enough Ram, Vram and CPU? Is there a way to work more smoothly in "Hi mode" with all "real-time reder options" selected?
Windows 11 Home 23H2
i9-9900k
48 Gb RAM
NVIDIA RTX 4090 - 24 Gb RAM
Driver nvidia 528.24
SSD NVME Firecuda 530
Iclone 8.4
Project specs :
Project Triangle : 5130406
Selected Tris : 35608 / 35608
VRAM : 7.0 / 24.2 GB
RAM : 11859MB
CPU : 5.8%
Posted Last Year
Posts: 15.8K, Visits: 31.4K
I have trouble with Environment Refection (repeated crashes) and have it usually turned off. Any other reflection, such as the Reflection shader will make the response slow.
I also had trouble with the latest Nvidia drivers; very slow response. I reverted back to v 537.58. I see you use an older driver than that. You could try v 537.58 and see if that helps.
ivan.g
ivan.g
Posted Last Year
Thank you for your prompt answer. I tried already to change the driver but I got the same result : the mouse movements are still shaking when moving in the Iclone 3d space when reflection shader and two other preferences are selected. So strange to face that problem with such a powerful hardware?
