Omniverse_Audio2Face iClone 7.93 Plugin Update Help
Posted By lnickers_724359 Last Year
lnickers_724359
lnickers_724359
Posted Last Year
Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)
Posts: 7, Visits: 143
Hello I modified the existing Omniverse_Audio2Face plugin so it works with my iClone 7.93. It now imports the face_anim.json that I saved from NVIDIA Audio2Face Applicaton.
I only tested it with one CC3_Base_Plus Character and not sure if it was default or Heidi-- concerned if it will actually work with other character profiles-- that may have custom morphs . My .json appears to only have the 60 base morphs and the jawbone.  I would need Reallusion feedback to know when the custom morphs come into play.
Thanks,
Nick
Here's my modified Omnivers_Audio2Face python script:
import RLPy
import json
import os
import math
from PySide2 import *
from PySide2 import QtWidgets
from PySide2.shiboken2 import wrapInstance
ui = {}  # User interface globals
events = {}  # Callback event globals
selected_obj = None
j_data = None
bs_pose_count = None
bs_frame_count = None
bs_names = None
srt_time = None
srt_frame = None
def get_picked_obj():
    global selected_obj
    if RLPy.RScene.GetSelectedObjects():
        selected_objs = RLPy.RScene.GetSelectedObjects()
        selected_obj = selected_objs[0]
    else:
        print('No Object Selected!!')
        selected_obj = None
def get_current_time():
    global srt_time
    srt_time = RLPy.RGlobal.GetTime()
def smooth(scalars, weight):  # -> List[float]:  # Weight between 0 and 1
    rrange = len(scalars)
    last = scalars[0]  # First value in the plot (first timestep)
    fsmoothed = []
    for point in scalars:
        smoothed_val = last * weight + (1 - weight) * point  # Calculate smoothed value
        fsmoothed.append(smoothed_val)                        # Save it
        last = smoothed_val                                  # Anchor the last smoothed value
    rfsmoothed = []
    for i in range(rrange):
        rfsmoothed.append(fsmoothed[rrange-i-1])
    last = rfsmoothed[0]
    bsmoothed = []
    for point in rfsmoothed:
        bsmoothed.append(smoothed_val)                        # Save it
        last = smoothed_val
    smoothed = []
        smoothed.append(bsmoothed[rrange-i-1])
    return smoothed
def open_file():
    global j_data
    global bs_pose_count
    global bs_frame_count
    global bs_names
    global srt_time
    global srt_frame
    file_dialog = QtWidgets.QFileDialog()
    file_dialog.setNameFilter("*.json")
    file_dialog.exec()
    get_picked_obj()
    face_component = selected_obj.GetFaceComponent()
    morph = RLPy.FloatVector()
    bone = RLPy.FloatVector()
    custom = RLPy.FloatVector()
    morph.resize(60)
    bone.resize(12)
    custom.resize(64)
    if (len(file_dialog.selectedFiles()) > 0):
        json_file_path = file_dialog.selectedFiles()[0]
        json_file_path_list = json_file_path.split('/')
        j_file_name = json_file_path_list[len(json_file_path_list)-1]
        ui["widget"].txt_json_file_name.setText(j_file_name)
        with open(json_file_path,'r') as animate_json_reader:
            j_data = animate_json_reader.read()
            json_animate = json.loads(j_data)
            bs_animation = json_animate['weightMat']
            bs_pose_count = json_animate['numPoses']
            bs_frame_count = json_animate['numFrames']
            bs_names = json_animate['facsNames']
            openStren = float(ui["widget"].jaw_open_strength.text())/100.0
            expStren = float(ui["widget"].expression_strength.text())/100.0
            get_current_time()
            srt_frame = RLPy.RTime.GetFrameIndex(srt_time, RLPy.RGlobal.GetFps())
            clip_length = RLPy.RTime.IndexedFrameTime(bs_frame_count, RLPy.RGlobal.GetFps())
            face_component.AddClip(srt_time, "Expression_Clip", clip_length)
            for i in range(bs_frame_count):
                try:
                    # BEGIN NAN DEBUG
                    # WEBSITE DOCS:
                    # this appears to skip the first 8 morphs in the data
                    # following the Docs, it seems true
                    # there are 60 morphs in the data, starting at the 8th index so this should be fine
                    for j in range(60):
                        morph[j] = bs_animation[i][j + 8]
                except IndexError as e:
                    RLPy.RUi.ShowMessageBox(
                        "Index Error",
                        f"Exception occurred at frame {i}, morph index {j}: {str(e)}",
                        RLPy.EMsgButton_Ok)
                try:
                    for k in range(51):
                        # BEGIN NAN DEBUG
                        # trying to prevent crash when attempting to load custom morphs- they may not exist in the data
                        # custom[k] = bs_animation[i][k + 68]
                        if (k + 68 < len(bs_animation[i]) - 1):
                            # 68 is the jawbone
                        # END NAN DEBUG
                        "Index Error",
                        f"Exception occurred at frame {i}, custom index {k}: {str(e)}",
                        RLPy.EMsgButton_Ok)
                try:
                    # BEGIN NAN DEBUG- I Got rid of the 60% scaling factor
                    # bone[7] = bs_animation[i][68] * 0.6
                    bone[7] = bs_animation[i][68]  # last morph is the jawbone
                        "Index Error",
                        f"Exception occurred at frame {i}, bone index 7: {str(e)}",
                        RLPy.EMsgButton_Ok)
                time_i = RLPy.RTime.IndexedFrameTime(i + srt_frame, RLPy.RGlobal.GetFps())
                face_component.AddExpressionKey(time_i, morph, bone, custom, 1)
    RLPy.RGlobal.ObjectModified(selected_obj, RLPy.EObjectModifiedType_Attribute)
def apply_jawopen_strength():
    #global bs_animation
    apply_a2f_animation(bs_animation)
def apply_a2f_animation(bsAnimation):
    if j_data is not None:
        exp_sl = int(ui["widget"].expression_smooth.text())
        open_sl = int(ui["widget"].jaw_open_smooth.text())
        bs_anima = bsAnimation
        bs_anim = bs_anima
        morph.resize(60)
        bone.resize(12)
        custom.resize(64)
        for c in range(bs_pose_count):
            anim_curve = []
                anim_curve.append(bs_anima[i][c])
            if max(anim_curve) is not 0.0:
                if c is 121:
                    if open_sl is not 0:
                        for sl in range(open_sl):
                            anim_curve = smooth(anim_curve, 0.5)
                else:
                    if exp_sl is not 0:
                        for sl in range(exp_sl):
                bs_anim[i][c] = anim_curve[i]
            for j in range(60):
                # skip first 8 morphs in the data
                morph[j] = bs_anim[i][j + 8] * expStren
            # apparently there are 51 custom morphs possible
            # starting after the jawbone which is index 68
            for k in range(51):
                if (k + 68 < len(bs_anim[i]) - 1):
                    custom[k] = bs_anim[i][k+68] * expStren
            # BEGIN NAN DEBUG- 68th index seems to be the jawbone
            # i.e. it is the 69th item in the list.
            bone[7] = bs_anim[i][68] * 0.6 * openStren
            time_i = RLPy.RTime.IndexedFrameTime(i+srt_frame, RLPy.RGlobal.GetFps())
            face_component.AddExpressionKey( time_i, morph, bone, custom, 1 )
    else:
            "Omniverse Audio2Face Animation Import - Operation Error",
            "Please apply an Audio2Face animation to the character first then click this button !!",
            RLPy.EMsgButton_Ok)
def setSound():
        file_dialog.setNameFilter("*.wav")
        file_dialog.exec()
            wav_file = file_dialog.selectedFiles()[0]
            wav_file_list = wav_file.split('/')
            wav_file_name = wav_file_list[len(wav_file_list)-1]
            ui["widget"].txt_sound_file_name.setText(wav_file_name)
            RLPy.RAudio.LoadAudioToObject(selected_obj, wav_file, srt_time)
    else:
            "Please apply an Audio2Face animation to the character first then Apply Sound !!",
            RLPy.EMsgButton_Ok)
def show_window():
    global ui, events
    if "window" in ui:  # If the window already exists...
        if ui["window"].IsVisible():
                "The current Omniverse Audio2Face Animation Import is still running.  You must first close the window to start another session.",
                RLPy.EMsgButton_Ok)
        else:
            ui["window"].Show()
        return
    # Create an iClone Widget
    ui["window"] = RLPy.RUi.CreateRDockWidget()
    ui["window"].SetWindowTitle("Import Omniverse Audio2Face")
    # Load UI file
    ui_file = QtCore.QFile(os.path.dirname(__file__) + "/mainwindow.ui")
    ui_file.open(QtCore.QFile.ReadOnly)
    ui["widget"] = QtUiTools.QUiLoader().load(ui_file)
    ui_file.close()
    # Assign the UI file to the Pyside dock widget and show it
    ui["dialog"] = wrapInstance(int(ui["window"].GetWindow()), QtWidgets.QDockWidget)
    ui["dialog"].setWidget(ui["widget"])
    # Add UI functionality
    ui["widget"].BT_apply_a2f.clicked.connect(open_file)
    ui["widget"].BT_apply_sound.clicked.connect(setSound)
    ui["widget"].BT_apply_jaw_strength.clicked.connect(apply_jawopen_strength)
    # Show the UI
    ui["window"].Show()
#def run_script():
#    show_window()
def initialize_plugin():
    # Add menu
    ic_dlg = wrapInstance(int(RLPy.RUi.GetMainWindow()), QtWidgets.QMainWindow)
    plugin_menu = ic_dlg.menuBar().findChild(QtWidgets.QMenu, "a2f_anim_menu")
    if (plugin_menu == None):
        plugin_menu = wrapInstance(int(RLPy.RUi.AddMenu("Omniverse Audio2Face", RLPy.EMenu_Plugins)), QtWidgets.QMenu)
        plugin_menu.setObjectName("a2f_anim_menu")
    a2f_menu_action = plugin_menu.addAction("Import Omniverse Audio2Face")
    a2f_menu_action.triggered.connect(show_window)
Threaded View
