Omnivers_Audio2Face PLUGIN index out of Range Exception iClone 7.93
Posted By lnickers_724359 9 Months Ago
lnickers_724359
lnickers_724359
Posted 9 Months Ago
Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)Junior Member (148 reputation)
Posts: 7, Visits: 139
Hello,
I'm using a CC3_Base_Plus character.
I managed to get the plugin, Omnivers_Audio2Face to load. But when I attempt to load the .json blendshape animation file,  there are index out of range errors.  I analyzed the json structure of the file, and there are the same number of frames as are in iClone project timeline (GOOD)  and there are 69 blendshape channels/json keys.  (GOOD).  I exported as USDA, USD from the Omniverse export from iClone so I could validate that all the blendshapes in the USDA match those in the omni_output_facial_anim.json.  And all is good, 69 blendshapes defined and 69 entries in the animation dictionary-- 69 per frame.
So, I used Copilot and ChatGpt to write a python debug script to analyse the data (see below).
The script below, prints out hundreds of frames worth of the 69 blendshape keys without error-- when loading in the .json from Audio2face.
When reading the actual Audio2Face plugin python code, i noticed a few "magic numbers" for ranges etc and am a bit concerned.  The plugin seems to be broken on lines 105 and 157.
In the snippet below, I could not determine why 60 is used when I see 69 blendshape names in the USD and the .json.    The 51, and the index calculation, [j+8] really threw me for a loop.  It would be greatly appreciated if you could push an update or email a working version for iClone 7.93 to:
lnickers@gmail.com cc: nickarthur.night@gmail.com
Here's the most mystical of the code blocks:
            for i in range(bs_frame_count):#(len(bs_animation)):
                for j in range(60):#(bs_pose_count):
                    morph[j] = bs_animation[i][j+8]
                for k in range(51):
                    custom[k] = bs_animation[i][k+68]
                bone[7] = bs_animation[i][121] * 0.6
Index out of Range Error Line 105:
Above, I don't see how we arrive at k+68 being valid or the index 121, but maybe it works in iClone 8???   Also,   I'm using a CC3_BASE_PLUS Character that i shipped to iClone from Character Creator-- hope that is OK.
The other code block that has an index out of range error is (line 157):
            for j in range(60):
                morph[j] = bs_anim[i][j+8] * expStren
            for k in range(51):
                custom[k] = bs_anim[i][k+68] * expStren
            bone[7] = bs_anim[i][121] * 0.6 * openStren
            time_i = RLPy.RTime.IndexedFrameTime(i+srt_frame, RLPy.RGlobal.GetFps())
            face_component.AddExpressionKey( time_i, morph, bone, custom, 1 )
On This line:  custom[k] = bs_anim[i][k+68] * expStren
Please help,  fast, I've lost a few days on this.  I took it as a time to learn a bit about the innards, but I have to generate some output. Smile
import json
def open_file():
    # Function to open a JSON file containing animation data and print the content for analysis
    json_file_path = f"C:\\Users\\nickarthur\\Videos\\ARTIST_ANIM_VIDS\\Night_OVER_EGYPT\\AUDIO_2_FACE\\A2F_OUTPUT\\a2f_export_Nights_Over_Egypt_Facial_Animation_bsweight.json"
    # Hardcoded path to the JSON file
    with open(json_file_path, 'r') as animate_json_reader:
        j_data = animate_json_reader.read()
        json_animate = json.loads(j_data)
        bs_animation = json_animate['weightMat']
        bs_pose_count = json_animate['numPoses']
        bs_frame_count = json_animate['numFrames']
        bs_names = json_animate['facsNames']
        print("bs_frame_count:", bs_frame_count)
        print("bs_pose_count:", bs_pose_count)
        print("bs_names:", bs_names)
        try:
            # Iterate over the loaded JSON data to analyze its structure
            # for i in range(min(5, bs_frame_count)):
                print(f"Frame {i}:")
                for j in range(bs_pose_count):
                    try:
                        pose_name = bs_names[j]  # Get the pose name
                        weights = bs_animation[i][j]  # Get the weights for the current pose
                        print(f"  Pose {j} ({pose_name}): Animation Data: {weights}")
                    except IndexError:
                        print(f"  Error: Pose index {j} is out of range.")
        except IndexError:
            print(f"Error: Frame index {i} is out of range.")
        # Optionally, you can print more details or analyze additional aspects of the loaded JSON data
open_file()
