Visits: 22.1K
Sorry if this is the wrong forum, but I looked ALL around and found no forum specifically for this add-on (and I really tried short of some search. It shouldn't be that hard). No matter what I do in terms of exporting an FBX I cannot get Accurig to load anything other than a profile pose, and not a T-Pose (even though the character is saved in a T-Pose. I tried from Daz, from XChange 7, and from Blender). Accurig just stubbornly turns the T-pose into an A-Pose, which wouldn't be bad EXCEPT it then rigs the arms into the body (the arms too close to the body, I guess, so the torso gets distorted). So clearly I'm doing something wrong - anyone have any ideas to help me out?
Posts: 5.3K,
Visits: 16.8K
A T-pose would give you slightly better result, but still not to perfection. Armpit weights still needs to be tweaked between Spine02 and Upperarm bones. Here is a reference:  But in general Accurig pulls a bind pose (the one character assumes when you select Restore Bind Pose in Animation tab). That could be an A or T pose depending on character. You may "force" a T-pose from A before firing an Accurig. Go to Proportion and dial upper arms up to 30 degrees (60 from 90 in this case).  Then in Accurig you'd get a T-pose
Visits: 22.1K
Thanks for the reply, Mr. G. I may come back to this if I have another problem. About ten minutes after I posted this I got it to work by bringing it into iClone, editing the bones and pose there, and exporting (yet one more time) as FBX. THIS time it held the T-Pose I constructed, and thus rigged the arms properly (it didn't help this was a robot and therefore could not use ANY torso involvement. But - I guess that's true of any character). I still don't quite understand why it wouldn't take the FBX into a T-Pose when Blendere and XChange did - they saw it correctly. So there's something wonky about how RL is processing FBX files. But I'm too old to try and figure it out.
Visits: 22.1K
Crap - I'm SUCH an old man I posted the same question again without even realizing I asked this a month ago. (Word to the wise - don't get old. It really sucks). I guess no one had an answer to this except me, so I guess I'll follow my own advice (which I promptly forgot. Again, old. Sigh).
