Hello,
I'm having a problem loading a CC4 Avatar that I have exported from CC4 to do weight painting in Maya.
When I export it from Maya, and import it into CC4 the model fails to load after I accept the following errors.
I'm not sure if I am exporting the CC4 avatar from maya correctly. I haven't made any changes, I've simply loaded it into maya and then exported it out but the file size is much higher,
export from CC4 - Camila.fbx - 76,592 KB
export from maya - Camila_export.fbx - 360,268 KB
This happens with every model that comes with CC4 and models I have created.
If I import the fbx I exported with CC4 back into CC4 (wiithout exporting it from maya), it loads with no issues.
Any help on this issue is appreciated!
Thanks!
