Posted 18 Years Ago
Posts: 23.1K,
Visits: 36.6K
Hi Michael, Are you using the Crazytalk 5 trial? Crazytalk 4 did have problems with sound in Vista but this shouldn't be a problem in Crazytalk 5. Also, I know it might seem obvious but have you made sure the volume control directly under the Crazytalk model is turned up. The slider goes left to right. Also make sure your main system audio is turned up to a reasonable level. You can test your audio is ok by playing some music or a video. If the sound is still missing why not contact technical Support for advice. Please use the support form below. http://www.reallusion.com/CustomerSupport/User/QForm.aspx
mpfeiler
mpfeiler
Posted 18 Years Ago
Last Active: 18 Years Ago
Visits: 4
Hello, I'm a newbe to crazy talk. After installing the demoversion and run the demo projekt, I can only see lips moving but can hear no sound or speech. my system is windows vista home premium. In the program itself I can find no configuration for sound output. I tried to install as administrator, but it's the same result. After exporting I can hear the demo sound. Thanks for all suggestions Michael
