jubala
jubala
Visits: 70
Character Creator not recognizing Zbrush Goz or Character Creator Zbrush pose plugin. I have tried Force reinstall GoZ from Program Files\Pixologic\ZBrush2019 (or whatever version you want to use) Manually copy over all the GoZ files from Users\Public\Pixologic\GoZApps\CharacterCreator to the character creator folder in Program Files\Reallusion\Character Creator 3\Resource\ICGoZBrush\CharacterCreator That workoaround is not workingt How do I make character creator goz to zbrush and also use the pose plugin to bring the model back to zbrush? Any help would be appreciated
Posts: 23.1K,
Visits: 36.6K
Please see the solution given in the thread below (make sure you are using the correct folder locations). https://forum.reallusion.com/513355/CC4-GOZ-ERRORHowever, if you continue to have problems, please contact Support and they will help you out. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
jubala
jubala
Visits: 70
Thank you I've ;looked at that post and see if that helps
jubala
jubala
Visits: 70
It's still not working with what was on the other post . CC is not recognizing export to goz then Zbrush or Pose Pulgin send current pose to Zbrush Pose Tools so something wrong with CC. Any help would be appreciated
Posts: 23.1K,
Visits: 36.6K
Thanks for updating us on this issue. Did you contact Support as I advised in my previous reply?
