Hi...
There are no options to change re
solution within CC4 itself. The only display option available is found in Preferences (CTRL+P) where you can check "Enlarge Font & UI" which is often required when using 4K monitors. All other re
solution changes need to be made in your computer's Display Settings (right click the desktop) where you can adjust the Re
solution and the Scale settings.
However, please be aware that you can close side panels or drag and resize them and also do the same with the viewport. There are also Workspace options available which can be found under Window on the Menu Bar. Finally you can change the aspect ratio of the viewport by change the Render settings found under Render > Render Video on the Menu Bar. Here you can select a 16x9 or 4x3 setting if you wish.
