Hi Daniel
When you click the Download (Motion) button under the ActorCore preview window, you should then have the option of selecting your actor (see below). You can choose from a list of actors purchased or uploaded from AccuRig.
Then once downloaded you will have a zip file that contains two folders. The Actor folder will have the avatar FBX and the Motion folder will have all the motion files in FBX format. You then just need to apply the motions to your avatar in your chosen 3D software (C4D in this case).
