How can I turn off the linkage reaction of joints?
Posted By philipjie117 3 Years Ago
philipjie117
philipjie117
New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)New Member (97 reputation)
Posts: 6, Visits: 108
I have a question about writing a plugin. When I rotate a joint of the avatar such as Caleb.iAvatar, I found that some other joints also rotate a little bit. Here is an example:
This picture is a side view of the avatar, which is in T-pose posture. The whole avatar is straight.
https://forum.reallusion.com/uploads/images/e0c9712a-9b66-4ffe-9580-f47d.png
When I rotate his left thigh, his whole body move down and forward a little bit, and his right knee is bent a little bit. I show the changes in parts of his body with red arrows in this picture. Hope you can understand what I say.
https://forum.reallusion.com/uploads/images/e4272a91-a260-4638-a135-8c6f.jpg
Is it a FK or IK properties of the avatar? I want to program to rotate only one joint and keep the others in their original position. To turn off the linkage reaction of joints, which API should I use? I had tried RLPy.RIHikEffectorComponent.SetActive(), but it seemed nothing happened.
        hik_type = [
            RLPy.EHikEffector_Invalid, RLPy.EHikEffector_LeftHand, RLPy.EHikEffector_LeftElbow,
            RLPy.EHikEffector_LeftShoulder, RLPy.EHikEffector_RightHand, RLPy.EHikEffector_RightElbow,
            RLPy.EHikEffector_RightShoulder, RLPy.EHikEffector_LeftFoot, RLPy.EHikEffector_LeftKnee,
            RLPy.EHikEffector_LeftHip, RLPy.EHikEffector_RightFoot, RLPy.EHikEffector_RightKnee,
            RLPy.EHikEffector_RightHip, RLPy.EHikEffector_Hip, RLPy.EHikEffector_Head, RLPy.EHikEffector_Neck,
            RLPy.EHikEffector_ChestOrigin, RLPy.EHikEffector_LeftToe, RLPy.EHikEffector_RightToe,
            RLPy.EHikEffector_LeftFingerBase, RLPy.EHikEffector_RightFingerBase, RLPy.EHikEffector_LeftHandThumb,
            RLPy.EHikEffector_LeftHandIndex, RLPy.EHikEffector_LeftHandMiddle, RLPy.EHikEffector_LeftHandRing,
            RLPy.EHikEffector_LeftHandPinky, RLPy.EHikEffector_LeftHandExtraFinger, RLPy.EHikEffector_RightHandThumb,
            RLPy.EHikEffector_RightHandIndex, RLPy.EHikEffector_RightHandMiddle, RLPy.EHikEffector_RightHandRing,
            RLPy.EHikEffector_RightHandPinky, RLPy.EHikEffector_RightHandExtraFinger, RLPy.EHikEffector_LeftFootThumb,
            RLPy.EHikEffector_LeftFootIndex, RLPy.EHikEffector_LeftFootMiddle, RLPy.EHikEffector_LeftFootRing,
            RLPy.EHikEffector_LeftFootPinky, RLPy.EHikEffector_LeftFootExtraFinger, RLPy.EHikEffector_RightFootThumb,
            RLPy.EHikEffector_RightFootIndex, RLPy.EHikEffector_RightFootMiddle, RLPy.EHikEffector_RightFootRing,
            RLPy.EHikEffector_RightFootPinky, RLPy.EHikEffector_RightFootExtraFinger, RLPy.EHikEffector_Quantity
        hik_effector_component = VDdata["model"].GetHikEffectorComponent()
        for type in hik_type:
            hik_effector_component.SetActive(type, RLPy.EHikEffectorType_Translate, False)
            hik_effector_component.SetActive(type, RLPy.EHikEffectorType_Rotate, False)
