ngallist
ngallist
Visits: 36
Hey guys! Trying the workflow for Headshot to Metahuman stuff. Works like a charm, no problem. However. The Diffuse Map is 2k and I cant find a way to export it at 4k. It exports as 4k in every other mode, no problem at all. Export to Blender in 4k? Gotchu. Export Fullbody to UE in 4k? Noproblemo. Export "Head Only" to Unreal? No 4k. And it´s only wrinkles and diffuse as well, the others export at 4k just fine. (See attached image) How can I export the Diffuse in 4k as well?
Posts: 23.1K,
Visits: 36.6K
Hi... Unfortunately you can only export with a 4K Diffuse map if it comes from SkinGen. Other source maps will be limited to 2K.
Visits: 2.4K
@Peter, I am trying to export with the SkinGen 4K texture as the export head and the textures are exported as blank colour swatches only instead of the baked texture maps. I tried with several characters and the same results. The normal exports are correct, though. I have reinstalled CC4 2 times, and still the same issue. What do we do to fix this?
