Export to UE5 with some shaders changed?
Posted By zelennej 3 Years Ago
zelennej
zelennej
Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)Junior Member (214 reputation)
Posts: 9, Visits: 77
Hello, we are having trouble with changing some shaders (teeth in particular). I need all the CC4 shaders to work as CC4 digital human, but for the teeth i need to use my own textures just with PBR shader. I have such setup in CC4 and it looks as I need, but after imported to UE5, the teeth are using the CC4 digital human shader again - can i set the export in CC4 to remember that teeth should use PBR shader?
I use the autosetup plugin for UE5 - i realize that might be the issue, but is there a way to make it work without disabling the plugin?
I guess i could change the shader manually in UE5 but that is not ideal for the pipeline we use - i should provide characters ready for devs to just drag and drop.
Thanks!
Threaded View
Threaded View
Forum Post Export to UE5 with some shaders changed? By zelennej ( 3 Years Ago )
