barca-8
barca-8
Visits: 700
Is there a way to have an object visible in the Editor and hidden during render? I have eye targets (spheres) that I want to be visible in the Editor but hidden when rendering.
Posts: 15.8K,
Visits: 31.4K
One way would be the make the eye targets dummy objects (this is setting under Modify). Dummy objects don't render. You can use Ctrl+D to toggle their visibility in the view port..
barca-8
barca-8
Visits: 700
Worth a try but, unfortunately, when I check "Set as Dummy," the object is hidden in the Editor.
What I'm doing for now is placing these type of objects in their own collection so I can hide them all at once prior to rendering. Not ideal, but...
Most apps I've used provide the option to selectively enable/disable objects at render-time. Seems like it would be extremely simple to implement.
Posts: 15.8K,
Visits: 31.4K
Press Ctrl+D to make dummies visible in the viewport. They will still not render.
barca-8
barca-8
Visits: 700
That did the trick! Many thanks!
