CC4: Open file changes from .ccProject to .iAvatar after export
Posted By barca-8 2 Years Ago
Posts: 15.8K, Visits: 31.4K
There is actually already a FT entry for it: #8867. The status is "Assigned", but it would be good to know what the actual status is.
You can add the points you mention above as comments in the FT entry, which may give it some more traction.
barca-8
barca-8
Posts: 218, Visits: 700
Thank you for confirming.
That's concerning on a couple of levels. Seems like it would be a very simple, quick fix.
I won't bother following up in the Feedback Tracker if it's a known issue.
This has been like that since time immemorial, unfortunately.
However, you should still be able to save the avatar as project, but you have to either go through the Content Manager or select File => Save As.
barca-8
barca-8
With a ccProject file open in CC4, after exporting the character to an iAvatar file, the title bar shows the current file to be the .iAvatar file that was exported (instead of the ccProject file. See screen shots below).
Also, while you can still edit the character, you can no longer save the ccProject using File->Project Save.
Something's not right. CC4 version 4.22.1612.1
