There might be some tutorials on youtube, but hobby software users rarely 'write-up' a detailed workflow analysis. I'll try.
The short version is that the content browser is a shared resource between CC4 and iC8. You don't need to think about intermediate export formats to get a figure from CC4 to iC8. As I recall the Content Browser was introduced in an update to CC3 and iC7, but it feels better integrated now and they don't duplicate resources anymore. There may still be
some exceptions, but there was essentially zero content management before….
I read in another of your posts you've been doing a lot of research and probably seeing some old advice that may now be obsolete. The Content Browser works now, the way RL's massive amount of content always should have. In other words, you won't find a lot of writeup analysis because it isn't over-complicated anymore, and users aren't suffering from the same degree of file bloat. (the figures i've saved to my custom 'Characters' folder are between 100-500MB each, fully dressed with 4K textures)
Final figures can be 'baked' to consolidate their texture layers and meshes – this is still a one-way process that can't be undone – but, for the most part, the things you save to the Content Browser are still editable.
Any CC3+ figure in an iClone scene can be replaced with a few clicks, preserving the animation, lipsync, etc. That means you can block out basic animations quicker with 'dummy' figures (same rigging, provided with iClone), and swap them with generic or in-progress versions of your CC3+ generation figures for lipsync and more detailed movements, and finally swapping with the full-quality figure before the final render.
A BIG animation project will still need human management… but (with Content Browser) there is less headache and the workflow is much more forgiving. You don't need to 'sync' figures at all… They are easily swapped with the current version of your figure.
why would the characters need to be dressed in CC? Adding clothes in iClone seems to work just fine.
There are editing tools in CC that are not in iC. If prefab content works then fine..., but if you are kit-bashing and combining content (a shirt from here, some pants from there) you will need to use a mesh tool sometimes to move the vertices (tuck shirt into pants, and paint-out any mesh bits that shouldn't show…, move hair out of jacket, etc).
3D figures and 3D content are not perfect, and Reallusion tends to favor lower-poly meshes so it runs in real-time – this is un-like DAZ who tend to favor high-poly meshes for still renders…. My opinion is there is a trade-off: Low poly is great when you have the tools to 'spot edit' the meshes and fix poke-through, which CC has. Very high-poly meshes may conform better (having more vertices to conform with) but can be a huge pain to edit and fix poke-through (having too many vertices to easily 'fix').
DAZ content is high-poly and difficult for users to edit, so they add a ton of morphs (making them bigger and more complicated) and consider it a 'feature'. RL's content has fewer morphs (if any) but is generally easier to edit with CC's built-in tools. It seems like more work than just moving a slider, but in the end having the edit tools is more flexible –– editing low-poly meshes is nowhere near as complicated as sculpting from scratch, and more versatile than trying to anticipate every necessary 'fit morph'. it's a middle-ground.
HOWEVER, there will be times where it is easier to just use a morph on the figure to alter the shape of the clothing because it just fits differently than other outfits. You don't need a whole new figure, you just need a figure that can still be morphed –– making breasts smaller/flatter under clothing for instance. You don't need to be quite so strategic in your workflow, saving a nude 'base' figure to dress in iClone –– that's not going to save you any time or headache, it would just limit the available character tools, and force you to try to do detail mesh/material work in an interface designed for animation.
Again, the Content Browser massively improves this workflow. It is easier now to do these corrections in CC and then swap the figure in iC. The whole reason for a meticulous workflow (like you have sketched above) is when it's impossible to go back a few steps, make an adjustment, and continue because you have to re-export to intermediate formats (sometimes called a 'waterfall' workflow because you can't go back up the waterfall). With the new versions and the Content Browser, you can take the figures back up the waterfall, make those adjustments, then continue where you left off.
Final thoughts:
in the last 2-3yrs, Reallusion has completely re-tooled. We use to need ANOTHER software entirely just to import/export common 3D formats (3Dexchange). That was so niche and workflow UN-friendly, it made CC and iC amateur choices in the bigger world of 3D. That's not true anymore. RL ditched 3Dexchange and now CC and iC are each more featured and grown-up (and more expensive). Again, nothing is perfect but the current versions are actually useable in a production, mostly because we no longer have to struggle with a 'waterfall' workflow at each import/export step.
TL;DR the current software is more forgiving, so we can be MUCH more cavalier with the workflow now, which almost eliminates all that file-exchange headache that held RL back.
