After importing an SVG, sync works, but file sync is broken if I go into Composer
Posted By shotymac 2 Years Ago
After importing an SVG, sync works, but file sync is broken if I go...
shotymac
shotymac
New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)New Member (47 reputation)
Posts: 3, Visits: 33
Hello all, I am hoping someone can help me figure this out or provide a workaround/fix.
I have CTA 5 set up to use Affinity Designer 1.10 to open and edit .svg files. After successfully opening/creating and importing a new .svg to the stage, I can see my character just fine, and as long as I stay in this mode, file sync works perfectly. Although with AD I do have to export the SVG each time a change is made instead of a simple save, but that is a minor issue and on any change and export, the character updates with the changes as expected within CTA 5.
The issue shows itself once I want to go into composer mode. As soon as I select to go into composer mode I am greeted with the following message: "Synced SVG/PSD editing will lose connection. Do you wish to continue?"
If I select ok and proceed, I now no longer can make synced updates. If I make any new changes to the SVG, it will pop up the PSD/SVG Create Options box, asking me to choose an import option and attempt to import the same SVG again as a new character. This behavior would indicate there indeed still is a sync of some type as CTA 5 still registers a change made to the file, but it no longer applies the change to the existing character. This is very problematic and I assume this isn't the intended functionality.
When reading the documentation and seeing the feature demonstrated this was not the behavior either... so I am wondering what is causing this behavior. Any help, hints, or tricks would be greatly appreciated.
