bach44 (4/26/2023)
Following this tutorial exactly.
https://youtu.be/LRllQ2AOjc0?t=688I can successfully import and animate regular characters in Unreal's Sequencer.
However, any character with wrinkles I cannot animate.
Part of the problem seems to be that on FBX import even with separate mesh and motion there is already an animation sequence and a animation blueprint associated with the wrinkle expression.
Then after importing the actual character animation I have 2 animation sequences!
I've tried using both in my Animation Track but neither work.
UE5 import settings changed.
Be sure you add the right fps into "custom frame rate" in the UE FBX import settings.(Animation)
IClone uses 60fps and CC 30fps by default.
And be sure you are using the latest CC_Setup
Last Year by
Bassline303
